Results 1 to 8 of 8
Thread: p-trap above drain pipe?
    DIY Junior Member sharkie's Avatar
    Feb 2014
    maryland
    Default p-trap above drain pipe?
    During a remodel of a master bathroom a few years ago my plumber shook his head when he saw the vanity that I had picked out. It had a shelf that was about 1 inch below where the pipe went into the wall. He said it would give us problems, but he would do what he could. So he made a p-trap and put it a little higher than the pipe going into the wall. I do not notice odors, and the sink drains OK but it is maybe a bit more dirty than my other sinks. My husband thinks it isnt a problem, he is more concerned with the drain in our other bathroom sink that has a funny downpipe with ridges on it. I think it ended up that way because it was an Ikea sink and the pipe sizes were different than what we had installed for the other sink that was in there. Hopefully I have attached the pictures correctly so you can see what I am talking about. I want to cut the shelf and put in a proper p-trap. Am I crazy?
    DIY Senior Member jim mills's Avatar
    Jan 2014
    nebraska
    The first pic is classic. The p trap is on backwards, and those corrugated lines should be outlawed. Looks like the popup drain is a bit too close to the wall, which may require a 1/8 or 1/16 bend to accommodate the properly installed p trap. The second pic shows an s-trap. You don't want that. Either remove the shelf & extend the tailpiece, or cut a slot in the shelf to accommodate the trap.
    Feb 2014
    maryland
    ok illegal - will do the fix, but what do I tell hubby who isnt too worried about legality? Are gases getting up in the drain?
    Sep 2013
    Maybe something like this, but with a clearance hole in the shelf rather than this method which makes maintenance not feasible. Alternatively, somebody might have an idea using an AAV to avoid the S trap problem.
    Jan 2014
    nebraska
    Quote Originally Posted by sharkie View Post
    Maybe...maybe not. It's just that it violates today's code, and a knowledgeable plumber would not configure it like that. If you are smelling sewer gas in that sink, the s trap is likely the problem.
    your "plumber" shook his head at your vanity choice....any good plumber would shake their head at his "plumbing"
    An S-trap can work TOO well, and there's no water left in the trap, or at least not enough to make a good seal. The choices are: redo the piping in the wall to raise the trap arm, or lower the trap so that the trap arm can go horizontal (well, small slope) into the wall.
    Sep 2013
    Here is the general idea of using an AAV, which are allowed in some places.
  1. Washer stand pipe, trap, and drain within one stud bay
    By bsperr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-29-2010, 08:01 AM
  2. garbage too low for drain pipe's p-trap?
    By silvertam in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-28-2008, 08:00 PM
  3. PVC P-trap to Metal drain pipe??
    By bellacielo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-30-2007, 05:53 PM
  4. P-Trap Lower than Drain Pipe
    By rayleeis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-16-2006, 08:09 PM
  5. Is 1 1/2" drain pipe ok for shower drain? and 2nd floor P-trap question...
    By paule123 in forum Shower & bathtub Forum & Blog
    Last Post: 06-12-2005, 10:15 AM
