My house was constructed in 1946-47. An upstairs shower stall drains into a short piece of 2" galvanized pipe, threaded on the shower-stall-drain end, which in turn drains into the bell joint of a cast-iron "J". The "J" then drains into another bell joint which is part of the stack. The 2" galvanized pipe is very rusty on the inside and probably should be replaced. My question is: How can the solder be cleaned out of these two bell joints so as to release the "J" so that the galvanized pipe can be replaced (with brass, hopefully)? It may be impossible, but it would seem to a non-professional plumber that maybe a torch could be used to partially melt the lead, which could then be pulled out with some sort of tool. The galvanized pipe can be cut, so to release the "J" it's really only necessary to de-lead the bottom joint, which fortunately is horizontal and accessible, then the top joint of the "J" can be de-leaded on a workbench.
I've read your other "Bell joint" posting so I think I can replace the "J" without any problem if I decide not to have a plumber do it, but I'd really like to have your advice on de-leading the joints.
