Water Leaking on back of house
dngrmys
Texas
It could also be the shower valve or piping to the shower head pull the valve trim plate and remove the shower head and cap the pipe then turn the shower
on and see if it leaks if not then yes it is the pan
Thanks - The plumber did check the meter and did not see any leaks. Is it possible to only leak when it's turned on?
dngrmys
Texas
Maybe get some UV dye and light kit and pour the dye mixed with 5 gallon bucket of water into the shower, then at night shine the light around the foundation see if it glows green.
Hmm...Interesting trick. That sounds like a good idea. The plumber recommended that we plug up the drain then fill the shower up to the lip and check for leaks. I do like your idea, though. It sounds more fool proof.
Houptee
Monmouth County, NJ
Yeh the UV dye is awesome for finding tiny leaks in car a/c systems and engine oil leaks etc. Just make sure you get the correct dye for water/coolant use not for oil leaks.
This is a good idea. Before you pull out the pan, make sure it is the pan. :)
Checking the piping in the wall, good first step.
Then plugging shower drain, and filling with bucket.
And here's an odd one for you. I once saw a shower with no reason for a leak other than showering without closing the shower door.
Nine months later I asked the homeowner about the shower. Husband was showering with the shower door open. Before he figured out that one, I had cut drywall looking for a source. I had asked about showering habits before that too. I didn't get an honest answer the first time.
dngrmys
Texas
So, if my plumber already confirmed no leaks (through the water meter) would we still want to do this step?
This would be to check the shower arm above the valve.
But if you plug the drain, and then fill the pan with buckets of water an let it set, and the water drains outside, then it's the pan.
You can check the pan first.
A broken hose faucet, like yours, can ONLY leak when it is turned on, (it would be a HUGE leak), and the pressure would drop INSTANTLY when it was turned off.
