I am replacing a vanity top, going from 1 sink to 2. I have everything I need with the exception of the drain components. The drain size is 1.25" drain, and due to space between the drain and wall, I was thinking of doing separate P-Traps and joining them together to the original existing drain to the wall. My problem comes to finding the Slip Joint T. I have spoken with several plumbing supply stores, and they all are telling me that they don't exist, and my google searches come up empty with "Slip Joint T 1.25 (or 1 1/4) inch drain." Is this true? I keep hearing that I have to do individual drains to the wall.
My curent drains are chrome, but I am ok switching to PVC if I need to as it is enclosed. I can also put the trap after the T joint if need be, but the space is close and would prefer to avoid this. I'd also prefer to not have to open up the wall as the vanity top is in place already, but I will IF I have to. Is there a way to transition a 1.25" drain from the sink to 1.5" and then back to 1.25" to go into the wall?
Any help would be appreciated.
