Results 16 to 30 of 31
Thread: Water heater temperature
  1. #16
    DIY Junior Member jhp1981's Avatar
    Jan 2014
    Texas
    I was told dip tubes could melt during soldering.
  2. #17
    Jan 2014
    Texas
    Used a cup of crushed ice. Waited for it to melt a bit and set thermometer to 32 F. Thermometer is pretty close to HVAC thermostat.
  3. #18
    DIY Senior Member Reach4's Avatar
    Sep 2013
    Quote Originally Posted by jhp1981 View Post
    I don't know about that, but if that happened, your hot water at the sink would only stay hot for a limited time before the cold water coming into the heater flowed to the hot water output. Your hot water stays hot many minutes once hot, so you are not having a dip tube problem.
  4. #19
    Sep 2013
    Is that an electronic thermometer with a probe? If so, try taping the probe to your hot water pipe coming out of the heater. Wrap insulating material around the pipe and probe combo. Use that to measure the water temperature during extended flows.
  5. #20
    Jan 2014
    Texas
    No. Its just an ordinary cooking thermometer.
  6. #21
    Mar 2011
    Houston, TX
    I never cooked at 32F before.
    You do know that Ice can be colder than 32F right ?
    Have Fun.
  7. #22
    Mar 2011
    Houston, TX
    It maybe could.
    Can you take a picture of it (Top, and T-stats) and give us the model number.
    If the dip tube is missing it will be mixing hot with cold water.
    Was it full of water before Power was applied ?
  8. #23
    In the trades Dana's Avatar
    Jan 2009
    If the pipe is installed in or under the slab, the odds are pretty good the temperature drop is simply due to the heat loss to the slab or soil. Neither concrete, soil, nor copper is very insulating, and running 120F water at 1-2gpm through half-inch pipe in a concrete slab is pretty much how radiant floor heating works. If any of that slab extends out beyond the wall insulation, it's going to be a bigger issue in mid-winter than during the summer
    Running the potable plumbing under the slab a common (but pretty crummy) way to route plumbing in slab on grade, bad for hot water heating/distirbution efficiency, and impossible to repair. But if that's what you've got, it's probably not cost effective to do anything more than bump the storage temp up. In some areas builders are required to insulate any buried hot water distribution plumbing to avoid this problem, and the efficiency hit associated with it. But even there it can still happen if the inspectors didn't see it before the slab was poured, or if it wasn't clear after the pour which was intended to be the cold side plumbing and which was the hot.
  9. #24
    Mar 2011
    Houston, TX
    Good theory Dana.
    If it was slab cooling, you would think it would have been a lot colder in the bathroom. (I assumed, Farthest Faucet, I Know...)
    They run the pipes in the attic here, and attic temp make a Big difference on a cold day.
    Not sure what part of Texas the OP is in. Never would have thought they would be in the slab.
    Have Fun.
  10. #25
    quote; May I ask the calibration procedure ?
    Normally to put it in boiling water and then rotate the needle to 212 degrees.
  11. #26
    Mar 2011
    Houston, TX
    That is what I would do, after it was removed from the heat.
    At sea level it will be very close.
  12. #27
    Sep 2013
    You might want to switch to about 208.5 degrees at 2129 feet above MSL.
    http://wiki.answers.com/Q/How_does_t...point_of_water
  13. #28
    Mar 2011
    Houston, TX
    Quote Originally Posted by Reach4 View Post
    Cant you just boil it longer ?
    LOL, Yes it was a joke.
  14. #29
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Did you actually measure the water temperature inside the water heater? It doesn't matter what the thermostat says...
  15. #30
    Boiling water never gets hotter than the boiling point over time, only with changes to the pressure (this has nothing to do with the temp of the steam if it can get extra heat). So, it depends entirely on the purity of the water and the air pressure above the open container...close that container and yes, the boiling point can be raised.
  1. Water Heater Temperature Question
    By Deltaman in forum Water Heater Forum, Tanks
    Last Post: 03-21-2010, 08:44 PM
  2. Gas Hot Water Heater-Temperature control
    By jkcsanchez in forum Water Heater Forum, Tanks
    Last Post: 08-22-2009, 11:30 AM
  3. Water Heater temperature
    By kayre in forum Water Heater Forum, Tanks
    Last Post: 04-10-2009, 03:47 PM
  4. Water Heater - temperature erratic
    By Lynne Marie in forum HVAC Heating & Cooling
    Last Post: 04-11-2008, 05:37 AM
  5. Water Heater - temperature erratic
    By Lynne Marie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2008, 11:45 AM
