Hello,
Should have known something was up with all the black tape around the drain when we bought the house...
Eventually it started leaking. It is a clawfoot tub.
Removed tape and what appeared to be caulk-like stuff.
Took some photos.
The pipe on top has a slightly larger diameter than the copper drain pipe.
The space between these two is very small, so I'm not sure how I can get anything in there?
I tried using some rubber-based caulk (clear) and some additional silicon based (white).
But water seems to have found a path onto the floor.
Help, we need showers!
N
Took some photos.
N
