How to replace frost free sillcock
Elapidae
Texas
I have a broken frost free sillcock (left the hose attached during a freeze... yes, another lesson the hard way...). I need to replace it but I'm not sure how. This is a newer house (built in 2012). I'm pretty sure it's 1/2 in PEX to the back of the sillcock but in looking at the construction of other houses going up by the same builder, I can see that there is no real access to the PEX to sillcock connection on the inside. On the outside, the faucet is mortared into the brick. It looks like I'd have to remove some bricks to replace it. I can't see any way to access the actual PEX to sillcock connection at all. I'm wondering if the PEX is likely crimped on an adapter that's then threaded on the sillcock such that I could perhaps just unscrew the sillcock from the outside and screw a new one in without having to tear out any brick. Is that possible (or likely) for a 2012 built home? I've attached pictures of a sillcock (pre-brick and sheetrock) installed by this builder on another house. In my case it's all bricked and sheetrocked.
Any advice? I'm not sure where to start or even which end of the sillcock to attempt this replacement.
Thank you in advance for any assistance.
If the hose bib is threaded into a drop ear 90 that is secured, then you might be able to thread a new hosebib in.
If not, you can always cut the 2x4 out of there and work from that end.
Gary Swart
Yakima, WA
A frost-free sillcock has about a 12" pipe from the outside that is connected to the supply line inside the house. The actual shutoff is done on that inside end. When shut off, the water in that pipe will drain, but as you discovered, when a hose remains connected to the bib, the draining will not occur. OK, now to the fix part of the question. The connection to the supply pipe is usually done with a tee and the threaded adapter for the bib to screw into. To remove and replace the bib you must have access to this connection. It requires 2 wrenches, one to apply counter pressure as you turn the bib with the other wrench. This is assuming you have copper pipe. With old galvanized one wrench might work. Replacing is the opposite. Notice the arrow on the inside end of the fixture. Do not try to remove the broken bib from the outside. You will almost certainly damage the supply pipe. The insulation you have on the hose bib pipe is useless because insulation does not heat the pipe. Side note: The faucet should have a slight tilt to the outside so it will drain. (with the hose off)
Additionally that faucet was designed to go much farther into the wall. Normally the bronze would be all of the way to the siding. Is that practical? If not, do what you can. Hmmm. Texas. You might be OK, but I really think you will be able to bring that in farther.
Elapidae
Texas
Thank you all very much for the quick replies and information.
Originally I got all excited about cutting an access panel in the sheetrock on the inside, crimping on some PEX fittings, adding and an interior cut-off ball valve, etc... Once I went over and looked at how they are actually installed (the pictures above), I realized I wasn't going to get access to much on the inside.
I'm really hoping the hosebib, sillcock, faucet (I'm sure I'm probably using the wrong term) is screwed into a 90 degree drop ear elbow that's secured to the 2X4 with the insulated 1/2" PEX crimped on to it. There's absolutely no way to get a wrench on it as is if mine is like the one pictured. Even if I sawzall the 2X4 out, I don't think there is enough inward play to get a wrench in there much less 2.
Again, the pictures are of another house being built near mine by the same builder and are examples of how they do it. The reason it's sticking so far from the wall in the picture is because they just haven't bricked it up yet.
The good news is that it's not an emergency. As long as I don't turn the faucet on, it doesn't leak. I may wait and try to catch them actually hooking up one of the sillcocks to see what's behind the 2X4. It sure would be nice if I could just unscrew it, wrap a little teflon tape on a new one and screw it back (and somehow have it miraculously wind up being upright). Thank you all again. I really appreciate it.
Cwhyu2
Consultant
Cincinnati OH
That picture with the hose faucet sticking out looks like it was taken before the brick veneer was installed.
Looks you may be able to twist it out.
Bluebinky
Des Moines, WA
It looks like you might need a bib with a longer neck -- like others have said, a 12 incher is about right for 2x6 studs and brick veneer.
That copper supply pipe should be as close to the interior as possible (without touching the wallboard and making noise).
Elapidae
Texas
Here's a picture of what's inside the insulation (supply line).
Elapidae
Texas
Yeah, thanks. If nothing else, the installation would force me to remove the hose. ;-)
Woodford makes a few models of frost-free silcocks that are designed to drain, whether a hose is on it or not. Since you're going to replace it, you may want to look into that company's products.
You have given a few pictures, but NONE of them show the critical thing, namely HOW is the faucet connected to the piping. THAT is what will determine HOW to replace the valve. Everything else is guesswork and conjecture.
Elapidae
Texas
That sounds like a good idea. I've heard the Woodford name a few times in my searching. Thanks.
Elapidae
Texas
Yeah, you're absolutely right. I went back and tried to look a little closer (without damaging the insulation). I believe it's connected through one of these:
Elapidae
Texas
I don't know if it will help anybody but it did indeed turn out to be a drop ear elbow. Just cut off the main water line. Unscrewed the old, screwed in the new. 5 minute job.
Congratulations on your success. It probably will help somebody. That somebody should consider using teflon tape on the threads.
