Results 1 to 3 of 3
Thread: Question about Moen Shower Valve 10399 extension kit
    DIY Junior Member bang0r's Avatar
    Mar 2007
    San Francisco
    Default Question about Moen Shower Valve 10399 extension kit
    I'd like to seek the advice/opinion from this forum regarding the Moen extension kit (Moen posi-temp 1200) prior to rushiing out to purchase the part.
    The symptom: the master bath shower valve is very difficult to shut off completely and smoothly; one has to wiggle or nudge the knob ever so lightly to stop the drip depending on the phases of the moon; the workaround is to remove the knob and deal with the valve directly.
    The causes appears to due to the thickness of the tile work, the distance from the valve in the wall to the handle has increased; so, when the handle is pushed to the wall, the valve cannot be shut off completely. Attached are two pictures of the Moen valve.
    I was told that the Moen extension kit will provides the additional length to accommodate for the increased wall thickness.
    Is the Moen posi-temp 1200 the correct part for the repair?
    Anything heads-up to watch out for when installing the extension?
    Please advice.
    Thanks in advance.
    Mar 2007
    San Francisco
    Just want to update the forum that I have called Moen phone support, and emailed them a picture of the shower valve while still on the phone and they let me know right away the part no for the extension kit is 10399. Attached is a picture of the installation instruction. The installation is very straightforward. Thank you.
    It's funny you posted that. I used one of the Moen 10399 extension kits on Wednesday.
    Some of the old Moen trims, the ones with the inward dish, require the extension kit if you plan to replace with a new "flat" style trim.
    Don't forget the 1225B cartridge while you are at it.
  1. Moen shower diverter in-wall valve question + Cartridge question
    By mln in forum Shower & bathtub Forum & Blog
    Last Post: 12-05-2013, 04:59 PM
  2. Moen exact temp volume contol valve question
    By J_Racer in forum Shower & bathtub Forum & Blog
    Last Post: 07-24-2012, 10:00 PM
  3. Moen Posi Temp shower valve adjustment question
    By jgulley31 in forum Toilet Forum discussions
    Last Post: 02-09-2012, 04:47 PM
  4. Extension of a Moen hydrolock sprayer hose
    By mclgracie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2012, 08:31 AM
  5. moen shower valve supply question
    By spooner in forum Shower & bathtub Forum & Blog
    Last Post: 02-18-2007, 04:42 PM
