Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Alternative to ball valve with waste
    DIY Senior Member jim mills's Avatar
    Jan 2014
    nebraska
    Default Alternative to ball valve with waste
    I'm adding some water supply shutoffs to zone a 4 unit apartment so the individual units can be serviced without shutting off water to the other units. I want to be able to drain the lines at the valve, but I don't have a lot of confidence in ball valves with waste. I've sheared a couple off opening them, so I get a bit paranoid when I see one. Any suggestions for a good alternative?
    Nov 2009
    Victor, MT
    I think you need to explain "I've sheared a couple of them off" in more detail for us to understand your concern.
    Jan 2014
    nebraska
    Cant remove them with my fingers, so I "gently" grab them with a plier to try & remove them only to have the entire nipple shear off.
    PS: I actually sheared one off with my fingers once.
    Nov 2009
    Victor, MT
    Put a tee and hose bibb after the valve.
    Jan 2014
    nebraska
    thought about that, but not sure it's legal.
    Jan 2014
    nebraska
    Hmmm. I thought I would get some responses to this. Do pex manifolds have waste drains? What's more annoying than having to cut a pipe full of water?
    There is one company that makes a ball valve, with a ballvalve drain on the side of it, normally used for servicing a tankless water heater.
    Jan 2014
    nebraska
    Yeah, I've seen those. Webstone I believe. Very spendy. Maybe I'll just forget the idea...
    Sep 2013
    Quote Originally Posted by jim mills View Post
    thought about that, but not sure [a tee and hose bibb after the valve] is legal.
    That is an odd reaction.
    quote; thought about that, but not sure it's legal.
    Why not? It is how MOST hose bibbs are installed. You just need to have the approved vacuum breaker on the hose bibb, because someone will connect a hose some day.
    Jan 2014
    nebraska
    Now all of the sudden I have a dozen hose bibs in my plumbing system. How rube Goldberg is that? I don't know about you guys, but I like to drain water lines before I work on them. Hmmm...another reason why I don't like pex manifolds with home run. Sure you can turn the water off to individual fixtures, but you can't drain the line.
    Nov 2010
    Maine
    Why not use ball valves with a waste. Take the cap off before you install it and put a little plumbers grease on the threads.
    Jan 2014
    nebraska
    You are probably right Tom. But almost every house in this area has non frost proof hose bibs outside with a valve with waste inside of the house that needs to be drained every winter. I have replaced countless numbers of them with frost proof spigots & have noticed that just about every one of them is corodded or stuck. Probably from neglect, but I just don't have a lot of confidence in them.
    Sep 2013
    Are you saying a boiler drain valve would not be allowed for this application?
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    If the boiler drain is not on a boiler or hot water heater then yes it needs a vacuum breaker.
    He could install a sampling valve and then a vacuum breaker would not be required.
    http://www.buyhardwaresupplies.com/?...Number=4537304
    http://hardwaredistributors.com/valv...FWRk7AodIiIAHA
  1. Check Valve or Ball Valve to HOLD PRIME
    By Mike Pastorelli in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-21-2012, 03:59 PM
  2. Ball valve
    By novice-man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2009, 09:28 PM
  3. Rubber valve seat alternative?
    By dlawb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2009, 06:00 PM
  4. Combo ball valve/check valve for ejector pump...
    By hhcibtpaun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-17-2009, 12:27 PM
  5. ball valve
    By gfe76 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-15-2008, 05:26 PM
