rpod83
Last night I peeled and trimmed a bunch of carrots, so there were carrot shavings and chunks in the sink. Usually my garbage disposal eats right on through that kind of food so I turn it on, turn the water on, and shove it all down.
The disposal starts doing its thing but gradually slows down and I realize the water is not draining, and it starts to back up. I turn off the disposal. When I turn it back on, I can hear the hum of the motor, but the blades are not spinning. Still no water drainage.
I have had the experience of the blades being jammed and needing to manually free them with a hex wrench under the disposal unit, but this is not that. The blades move freely, both with a hex wrench and when I stick my hand down there and spin them. I can't feel anything clogging jamming anything with my hand.
One interesting detail is that if I turn the disposal on, and I hear the hum but there is no blade movement, I can get it doing by putting a wooden spoon handle down there and manually spinning the blades. If I do it fast enough, it's like the blades pick up and and start spinning on their own.
Overnight the water did not drain. I'm at a bit of a loss on what to try next. Even if the disposal broken the water draining must mean there is a clog somewhere, right? Should I try something like Liquid Plumber?
Any ideas on what's happened to my disposal? Or suggestions for next steps? Thanks!
