Results 1 to 6 of 6
Thread: boiler pressure regulator
    DIY Junior Member RyanA's Avatar
    Feb 2014
    Tennessee
    Talking boiler pressure regulator
    does anyone have a make or model of a PRV that can go down to 12 PSI? I have one now that goes down to 25 PSI and I'm afraid if I fire the boiler my water pressure will blow the relief. Most PRV go to 25 min...help
    Mar 2011
    Houston, TX
    Quote Originally Posted by RyanA View Post
    Watts make them that are set for 15 PSI.
    http://media.wattswater.com/1910265.pdf
    Good Luck.
    Feb 2014
    Tennessee
    Good Luck.
    Thanks Don!
    I'm good!
    This is a hot water, not steam? Most domestic boilers need somewhere around 12-14psi of water pressure in them to operate properly. If it is properly setup to account for expansion when the water is heated, it should not rise much, if at all. The safety valve needs a bit of margin, and since most boilers can handle up to somewhere around 50psi, 30psi safety relief valve gives both the normal pressure range and the overall boiler's safety range in the sweet spot. Changing that valve to 15psi is just asking for problems unless I'm missing something. If you have an autofill valve, once the system is filled properly, shut the supply valve to it off, and the boiler should never get over-pressurized.
    Mar 2011
    Houston, TX
    The one I posted is adjustable.
    It is just preset at 15 PSI.
    But it can be adjusted down if needed.
    Nov 2010
    Maine
    Watts S1156F or the Taco 339 both are designed for boilers and both are adjustable and come set at 15lbs.
  1. Pressure test PEX with air compressor pressure regulator
    By chuckd83 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2014, 10:07 AM
  2. Water pressure regulator problem pressure increases overnight
    By igornys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2013, 12:45 PM
  3. Watts Pressure regulator does not hold water pressure
    By goshenplumber in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-05-2013, 07:23 AM
  4. Bad pressure regulator?
    By dabensys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-28-2010, 05:53 AM
  5. Changing water pressure on house pressure regulator.
    By kskier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 09:20 AM
