Thread: Cello Fittings? Any opinions?
    Default Cello Fittings? Any opinions?
    I'm looking to place a decent size order with pexsup*** for PEX and related bits. On all the Pex related materials I'm going with Uponor (Wirsbo) but I'll still require a few copper / brass fittings for tieing into valves and copper pipe.
    The primary brand they carry is Cello, which is made in Canada. Locally I can get Nibco or Mueller.
    I'd like to just include what I need in this order but if you guys think these other brands are better, I'll find them elsewhere.
    What do you think?
    Louis
    No opinions on these choices?
    DIY Junior Member Patriot's Avatar
    Dec 2013
    NJ
    Quote Originally Posted by Mathelo View Post
    If you order copper sweat fittings from pex supply, they are going to send you EPC fittings, not Cello, even though their website advertises Cello.
    The local supplier I use sells EPC fittings and they seem to be ok although I was not happy with them at first. Just for the heck of it, I weighed Nibco, Mueller and EPC fittings. The Nibco was the heaviest, EPC was slightly less and Mueller was a lot less.
    Quote Originally Posted by Patriot View Post
    Thanks for your reply.
    I can get Nibco at my local Home Depot. Based on your weight test, Nibco sounds like a better way to go. I also don't think it is cool that pex supply advertises one thing and sends another.
  1. Can I mix PVC pipe with non-PVC fittings? Are there higher quality copper fittings?
    By Upton O Good in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2013, 05:57 PM
  2. Opinions please
    By 6t7gto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2013, 03:56 AM
  3. bronze fittings and copper fittings
    By diyfun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-12-2012, 12:03 PM
  4. Your opinions
    By Fudog in forum Electrical Forum discussion & Blog
    Last Post: 02-21-2008, 09:29 AM
  5. schedule 40 dwv fittings and pressure fittings
    By Ed from chicago in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-02-2005, 07:14 PM
