Results 1 to 7 of 7
Thread: flow check valve + circulator or circulator with flow check integerated?
    DIY Senior Member diyfun's Avatar
    May 2011
    MA
    Default flow check valve + circulator or circulator with flow check integerated?
    I am in the position to make a decision to use a flow check valve plus a circulator or just a circulator which with an integrated flow check valve inside such as 007-IFC series. which way you will go?
    Nov 2010
    Maine
    Circ with check valve.
    when the check valve wears out or fails, it will be a lot cheaper to just replace a check valve.
    Nov 2010
    Maine
    Nope, it's cheaper and a whole lot faster to change the check valve in the circulator but, I've never seen one fail
    Many (all?) of the Taco circulators use a cartridge to replace the wearable parts. Not sure what the relative costs are verses just buying a whole new one, but swapping the cart is certainly easy.
    we are referring to the "check valve" not the impeller cartridge, and if the check valve NEVER fails it must be the only "eternal" plumbing part in existence.
    Nov 2010
    Maine
    Maybe. I've been installing Taco 007's with the check valves since they 1st came out and I haven't had a single check valve fail yet. If you look at the design, I'm not sure how they could fail unless something wedged itself in there. Then again, I don't think I've had to replace more than one or two regular flow checks in 40 years either unless the packing leaked. Most can be "adjusted" when they stick open with a hammer to the side.
  1. a separate flow check valve or a circulator with a flow check valve?
    By diyfun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-08-2012, 08:31 PM
  2. Starting design - check my flow/pressure please
    By Lakee911 in forum Irrigation / Sprinkler Forum
    Last Post: 10-07-2011, 05:11 PM
  3. Swing Check vs. dual check vs. double check valve
    By colbymom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-10-2011, 01:19 PM
  4. Custom cycling of circulator and zone valve...
    By niknarg in forum HVAC Heating & Cooling
    Last Post: 12-10-2008, 06:46 PM
  5. Taco Flo check circulator pump
    By MarkHash in forum HVAC Heating & Cooling
    Last Post: 10-04-2007, 08:23 PM
