Results 1 to 7 of 7
Thread: Temporary Toilet Install
    DIY Junior Member C Williams's Avatar
    Jan 2012
    Vancouver Island
    Lightbulb Temporary Toilet Install
    So Iíve build our new house in a remote community in BC. The house is now to lock up, the plumbing is in and Iím just working on electrical. At my glacial pace we have a long haul ahead of us but I wouldnít trade it for anything. We are not living there yet but are there daily working away and what we really want is a functional toilet. It will be months before we get a finished floor in either bathroom so I was wondering if anyone can recommend a way to temporarily install a toilet without compromising the installation of the permanent toilet flange on the finished floor? In each bathroom there is a 4Ē abs stub protruding up from the floor. One through concrete and the other through plywood. I donít care which one I use. Suggestions?
    Many thanks in advance.
    If you know the thickness of your desired flooring, you could lay some sheet goods there, install the flange at that height, and temporarily set the toilet. While not a horrible situation, ideally the flange will sit on the top of the finished floor. Or, if you have access below, you could just set it on the subfloor, and then cut it off and reinstall new when you add the finished flooring. If you plan something like sheet goods (vinyl), then just set it on the subfloor...the thickness of that won't matter, but it could if you were to add a second layer of ply and maybe some cbu, and tile.
    Most toilets won't sit properly unless the flange is either on the finished floor, or maybe as low as even...but for the finished thing, on the finished floor is still the way they were designed to fit.
    DIY Senior Member houptee's Avatar
    Aug 2008
    Monmouth County, NJ
    Or maybe raise the toilet up on a temp platform above the pipe coming out of the floor. If you have a small wood pallet laying around put a piece of plywood on it cut a hole for a flange screw it to the plywood and put a piece of extension pipe and a rubber fernco to the stub coming up. Use a waxless rubber toilet gasket so you can reuse it when you permanently set the toilet.
    Raise the floor temporarily and use a "compression fit" flange which you can remove when ready to install the permanent floor and flooring, then install the permanent flange on top of that.
    Jan 2012
    Vancouver Island
    Thanks HJ, Jadnashua, and Houptee.
    Hj's answer sounds good. I knew someone here would make me aware of a product that I didn't know existed. Now I just need to lay my hands on a compression fit flange that fits inside a 4" abs pipe. Since it is a compression fitting I'm assuming I don't care if it is PVC or ABS. I only see PVC ones online.
    You guys Rock! Thanks.
    Aug 2008
    Monmouth County, NJ
    Here is what HJ is talking about it pushes into the pipe.
    http://www.homedepot.com/p/Sioux-Chi...6-GP/202313119
    Here is a waxless gasket
    http://www.homedepot.com/p/Unbranded...BL01/203564758
    Jan 2012
    Vancouver Island
    Thanks houptee,
    The Canadian Home Depot doesn't sell either product but our local wholesaler carries Sioux Chief so I will check with them.
  1. Temporary dishwasher install during a remodel
    By fihzy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-07-2014, 07:43 PM
  2. Toto Aquia Temporary Install on Concrete Floor
    By ipedalfaster in forum Toilet Forum discussions
    Last Post: 10-14-2013, 10:41 AM
  3. Temporary Toilet Install?
    By Rich H in forum Toilet Forum discussions
    Last Post: 04-29-2006, 05:01 AM
  4. temporary shower?
    By michaedt in forum Shower & bathtub Forum & Blog
    Last Post: 12-04-2005, 05:09 PM
  5. Temporary Bathtub?
    By rwhoch in forum Shower & bathtub Forum & Blog
    Last Post: 11-18-2005, 11:19 AM
