Results 1 to 15 of 20
Thread: Master Tiler or MasterCraft tiler, tile adhesion issues?
Hybrid View
    DIY Junior Member Natup's Avatar
    Oct 2013
    Toronto
    Default Master Tiler or MasterCraft tiler, tile adhesion issues?
    Dear setters (and sympathetic others)
    I’ve been engaged in my own bathroom renovation for the past 2 months. Initially, I was going to do the tiling myself, but decided that this best be left to a master tiler. I did my research and decided to go with a company supposedly has an excellent reputation. They advertise, “all master setters”, guarantee satisfaction and a 3 year warranty.
    In prep for the reno I had managed to get the floor perfectly level (sistered joists, blocking, new subfloor, and plywood underlayment). I laid a heating mat in SLC. I messed the leveling up somewhat and was prepared to do a corrective pour prior to unleashing the setter. However, the owner (of the company: I’ll call him owner) said he’d prefer that I let their respective setter take care of this – I figured they would perhaps use a dry pack around the low perimeter areas, or mortar, and frankly I was happy to oblige.
    On day one, the setter and his assistant showed up and seemed unprepared for the need to level. Indeed he arrived without a level. I offered him several of mine. As you can imagine, first impressions were not great: his wet saw is a small, cheap mastercraft (Canadian Tire; http://reviews.canadiantire.ca/9045/...ws/reviews.htm) table-like saw. He also neglected to bring drop sheets or any protection for the newly installed tub, etc. etc. (perhaps the tools don’t make the master eh!). Regardless, my confidence in the project didn’t start well.
    He laid the ditra that I provided (fortunately, I had unmodified thinset, and a ditra trowel); unfortunately, he used a modified thin-set over the ditra. Later, in regards to this, the owner laughed at me, suggesting that the Ditra warranty meant nothing compared to his warranty (I hope he’s right).
    Hopefully, this is enough background info other than to say that I did express to the owner my concerns regarding the presumed “expertise” of the setter; and he did show up for an inspection. I have several questions:
    1) Setter used a ½ x 3/8? trowel and back-buttered much of each tile; but he did not appear to have compressed notches on setting – i.e. it appears that some parts of tiles are resting on the notches.
    2) I know that John W argues for near 100% thinset-tile-wall coverage. What is your standard? For instance as per my pics there are thin notch gaps running under some tile (see pics demonstrating depth) – is this acceptable?
    3) I have already had the setter redo substantial components of the tile (particularly within the niche – inspired and advised by J Whipple), but in general (superficially) how would you grade the quality of his work? For instance the long plank tile was difficult for him to rip (he believes that the jagged cuts (see pick) will be hidden at ceiling and floor by chaulking
    4) During the inspection, the owner assured me that the setter’s mortar technique looked good (he could tell by looking through the unfinished grout spaces. Regardless, he assured me that satisfaction was guaranteed and that if any issues arise I have a three-year warranty. Am I being a paranoid homeowner here (I am willing to admit this) or do you foresee adhesion issues, and when (e.g. 4 years)?
    5) Regarding the floor: it is level to bubble in the centre (at worst, there is about ¼ dip at tub. To be fair, the owner said that he’d have the tiler correct the entire floor (yet he implied that this would be unreasonable given that ¼ inches is within industry standard). Frankly, I feel for the setter – ultimately he would pay for it. I said that it would be fine as long as the toilet didn’t rock. I just checked (prior to grouting) and it rocks just a tiny bit. I know this can be shimmed – is this acceptable?
    Sorry for being long winded. Ultimately, I feel for the poor setter. He has done a good 2 1/2 days work thus far and has been compliant and relatively good natured with my requests. Frankly, I'm inclined to just have the job completed. I am more pissed with the owner: he promised a master setter. I was shocked when, in front of me, as we were going through the inspection, he provided the setter with a list of equipment that a setter should possess. He demanded that he purchase these tools prior to his next job start Monday – I thought – what about my job?
    Btw. Setter is coming by Sunday to grout.
    Hal
    Oct 2013
    Toronto
    Default More pics: the good
    Niche inspired by John W. Had him redo the grout lines.
    Oct 2013
    Toronto
    Default The Ugly??
    Gaps formed by notches Is this OK? btw - I was very careful not to damage the 1 day old thin set.
    Oct 2013
    Toronto
    Default more pics
    These were pried from the wall to fix the niche
    Oct 2013
    Toronto
    Illustrates depth of notch gaps:
    IMHO, far from 'master'. In reality, far from the minimum industry standards. On a floor, industry standards call for 100% of all edges, and at LEAST 80% coverage of the rest of the tile, with the goal being 100%.
    If you read the Schluter Ditra Installation Manual (you can download it from their website), the reason they recommend a dryset mortar on top of Ditra is that unless they used a rapid set mortar, with a large tile, after waiting over two months, the mortar still hadn't dried sufficiently to support the tile properly. What does that do to the overall strength? Well, the main reason why a modified is stronger than a dryset is that it encapsulates the cement crystalline spikes as they grow while curing and supports them. But, what happens if stress is applied before because they have not properly dried? The cement crystals break and lose strength. A good dryset often has more cement per volume than the modified AND cures just fine in a known, predictable timeframe. I just love it when people think they know more than the people who design, specify, and warrant their stuff.
  1. Tile & Shower Failures: A closer look a spot setting tile. Why this is a bad idea.
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 02-04-2014, 07:30 AM
  2. Tile subfloor issues
    By Str8sh0otr in forum Remodel Forum & Blog
    Last Post: 12-02-2012, 12:16 PM
  3. Over zealous tiler
    By Rima in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2012, 05:47 AM
  4. Tile floor closet flange issues. With picture.
    By coyote556 in forum Toilet Forum discussions
    Last Post: 07-27-2007, 03:44 PM
  5. Replies: 9
    Last Post: 01-02-2007, 12:31 PM
