Results 1 to 2 of 2
Thread: Oil boiler with tankless coil quick question read all posts and need one more answer
    DIY Junior Member Jeff Sicoli's Avatar
    Jan 2014
    New York
    Default Oil boiler with tankless coil quick question read all posts and need one more answer
    I have a laars Newport oil boiler with tankless coil. The system is completely drained and when I fill the pressure relief valve leaks and psi goes over 30.
    I have replaced the following
    Expansion tank and air release value
    New pressure relief valve and before pressure relief value there is also another air release changed that also
    I also adjusted the pressure on the auto fill valve which didn't help so I put it back to Orginal setting
    I see everyone posts turn off the valve that feeds the auto fill and see if psi keeps rising. I did that and the psi stops rising. But my problem is the shut off valve is before the auto feed valve and the copper that leads to coil in the same line so how else can I checkif iit's the coil or the auto feed
    Thank you very much
    Nov 2010
    Maine
    You have to isolate the piping by cutting in another valve.
  1. New tankless boiler coil question
    By travis9791 in forum Tankless Water Heater Forum
    Last Post: 01-07-2013, 09:20 AM
  2. Replies: 4
    Last Post: 01-27-2012, 03:30 PM
  3. Bypassing Tankless Coil in Boiler
    By pvtjoker39071 in forum Boiler Forum
    Last Post: 12-12-2011, 08:34 AM
  4. Tankless Coil for Oil Boiler or any other suggestions please...
    By thumbiman in forum Water Heater Forum, Tanks
    Last Post: 10-13-2011, 07:16 PM
  5. tankless boiler coil
    By daves in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2005, 04:59 PM
