Results 1 to 7 of 7
Thread: Basement bathroom floor broke up. Does this layout work?
    DIY Junior Member GTJackets's Avatar
    Dec 2013
    TN
    Default Basement bathroom floor broke up. Does this layout work?
    Is this a proper way to plumb a basement bathroom?
    1. lav drain
    2. shower
    3. toilet
    4. vent for toilet
    5. is hard to see but is a 2" Wye rolled above the horizontal to vent the shower.
    Question:
    Is the toilet vented by the vent for the shower(#4 in the photo)?
    Or is the toilet wet-vented by the lav drain(#1 in the photo)
    The biggest concern if venting between the shower and the toilet.
    The shower vent will also vent the toilet, but normally you like to see the vent come off at a 45 or vertical and not flat.
    You may want to at least roll it to keep it above the flow line of the shower waste line.
    If you have other bathrooms coming down that line, then the lav woudn't really be venting the toilet.
    I vent before a fixture enters a waste line.
    Dec 2013
    TN
    This is not my setup but I am in planning stages and looking at other's rough in
    Good point on venting before a fixture enters a waste line.
    Dec 2013
    TN
    As a clarification, fitting #5 is a 2" Wye and will be rolled above the horizontal to vent the shower. Like the drawing below.
    DIY Member yngwie_69's Avatar
    Sep 2009
    prince rupert, BC
    though lav sink was the only thing u could wetvent a toilet with. wouldnt a double wye be better and vent toilet of the left side and tie into the shower vent
    Dec 2013
    TN
    Quote Originally Posted by yngwie_69 View Post
    Not true but the lav is the most common
    quote; Good point on venting before a fixture enters a waste line.
    If the vent is after the fixture enters a waste line the vent will be decorative, i.e., it will look pretty but won't serve any actual purpose.
  1. Need quick advice on 3 floor bathroom layout
    By Jozart in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-12-2013, 10:09 AM
  2. DWV Layout Basement Bathroom - layout review
    By great white in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-13-2012, 05:28 PM
  3. new basement bathroom layout
    By pumsaw in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2009, 06:06 AM
  4. Basement plumbing, layout & third floor waste stack HELP
    By novicepiper in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-11-2009, 01:11 PM
  5. Basement plumbing, layout & third floor waste stack HELP
    By novicepiper in forum Remodel Forum & Blog
    Last Post: 05-01-2008, 07:33 AM
