Hello, a (hopefully) quick question. I'm planning on replacing the main waste/vent stack and associated vent and drain piping at my house in Seattle. The current stack is 4-inch cast iron, and my plan was to replace all of it down to the hub coming out of the foundation with 3" ABS and use a Fernco (or equivalent) donut at the junction of the CI and ABS. The issues is that I relayed my plan to my brother-in-law who's a plumber out east and he said that the first three joints in the waste stack need to be leaded. I looked through the code (International Plumbing Code 2009...I think there's a newer version, but couldn't find it online) and couldn't find anything like that. It could be that the three-joint thing is a local code that he has to follow. I guess I can see the logic in having a very tight seal at the entrance to the building sewer. If the three-joint rule is real, then conceivably I could cut the CI higher up, above the first three joints and join it with a Fernco coupler, but that doesn't seem like a better joint than the donut. Or, I could use a manhoff fitting to transition from the CI to the ABS (do they make ABS manhoffs? I've only been able to find PVC ones...) at one of the CI hubs.
Anyway, I guess the big question is: can I just transition from CI to ABS at the first hub out of the foundation using a donut or manhoff, or do I need to go three leaded joints up (seems arbitrary) then transition?
