Thread: Bathroom sink trap: PVC or Polypropylene
    DIY Member adrianmariano's Avatar
    Jan 2007
    Massachusetts
    Default Bathroom sink trap: PVC or Polypropylene
    I'm removing some badly constricted steel pipes that drain my bathroom sink and tub and replacing with PVC. The existing trap under the bathroom sink is a heavy weight 1.5" sched 40 PVC and screws together with metal nuts. I can't reuse all of it because the end piece is glued to some ABS, though perhaps I can just replace that one part.
    Now it seems there is another option for traps: a lighter weight "slip" joint trap made of polypropylene instead of PVC. This might be easier to install because the slip joint provides more flexibility when making the final connections. I think this is 1.25" pipe, so it's a bit smaller.
    My question is, does it matter which type of trap I use? Is one of the two types superior? Or should I just pick my trap based on what turns out to be the easiest to install?
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    No it doesn't matter. The only thing that matters is "no leaks".
    Quote Originally Posted by adrianmariano View Post
    I prefer tubular traps over the solvent weld traps. It's also easier to remove them when needed, in case you need to run a hand snake through the drain.
    Jan 2007
    Massachusetts
    Thanks for the advice.
    I would say there's a second thing that matters beyond "no leaks", which is that water actually drains. Or to be more succinct: no clogs. And of course I'd like it to work properly for a long time, so no leaks or clogs in 20 years. My existing piping doesn't leak...but it also doesn't drain very well. There's a temptation to think that the heavier built product is better, that it will last longer, and so on. But it doesn't have to be true.
  1. Bathroom sink trap height
    By txag in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-04-2010, 05:50 AM
  2. P trap requirements for bathroom sink
    By larry528 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-17-2009, 07:31 PM
  3. 2" rough-in for Bathroom Sink P-Trap?
    By bjferri in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-25-2008, 06:31 PM
  4. Bathroom sink p trap or t trap
    By ksdad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2007, 06:36 AM
  5. Need advice on bathroom sink p-trap
    By funwithpowertools in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2007, 07:44 PM
