Thread: utica /replace pressure valve ?
    DIY Member 4uzindian's Avatar
    Oct 2013
    trenton nj
    Default utica /replace pressure valve ?
    1989 model dv.it has aslight drip now because its old and i opened it to test it.any tips on the procedure to replace it?
    Sep 2013
    Turn off the water. If you don't have a handy whole-house turnoff valve, get one installed. http://www.watts.com/pages/learnAbou...s.asp?catId=64 You will probably need a plumber for this. If you were looking for help, to do it yourself, not a good post.
    How did it only have a slight drip when you opened it rather than gushing water?
    The valve can often end up with a bit of mineral deposits on the stem making it hard for it to return and seal and the seat may end up getting hard after long use. Works fine until you open it. It's safer to check it and ensure it can open, but you have to be aware that it may no longer seal, and need replacement. Sometimes, after a delay, it may stop dripping, but it's a sign it should be replaced. While a boiler has various safety controls to prevent it from being overpressured, you really want that last ditch pressure relief valve to open if it needs to.
    Oct 2013
    trenton nj
    thanks for reply.it did ghus when i opened all the way.put a new valve in the smorning. it works just fin. read thru many how to's of this .it's ok now.thanks again .if something else comes up.i'll be back with my tail between my legs.thanks for the tap on for watts products .it was very infomative.for now i'll be closing this post.
  1. utica boiler leaky valve #2
    By 4uzindian in forum Boiler Forum
    Last Post: 11-17-2013, 12:20 PM
  2. utica boile at 35 psi ooh
    Last Post: 10-04-2013, 12:56 PM
  3. Replies: 5
    Last Post: 07-05-2011, 05:43 AM
  4. Low pressure, pump stays on - tank, pressure switch? Replace all?
    By applebach in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2011, 04:51 AM
  5. Need to replace Shower mixing valve with separate cutoff valve for inputs.
    By OfficeLinebacker in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2006, 09:06 AM
