Results 1 to 6 of 6
Thread: 3 way diverter
    DIY Junior Member trickle's Avatar
    Jan 2014
    Saskatchewan
    Default 3 way diverter
    A valve I bought will do 3 seperate items but not 2 together.
    I want to run one or a second or both.
    Can I use a w with 2 check valves to solve this? Can I bury the check valves in a Canadian wall? Is there a type/brand of check valve I should use?
    Jul 2009
    North Vancouver, BC
    It would be easier I think to replace the shower fixture or to decide what two fixtures you would want to use at the same time. Then purchase a flow valve for that one dedicated fixture so you can run it by it's self....
    Having a rain head and hand held at the same time is perfect for showering couples!!!
    Jan 2014
    Saskatchewan
    I only have 2.
    Rain and hand held.
    Position 1 would be 1 head
    Position 2 would be the hand held
    Position 3 would be both.
    I considered jets but the few timed I have used I was not overly impressed. And, i fear, the water usage would be more that I can take; its for my 3 daughters bathroom.
    The other thing is the valve I bought is thermostatic with diverter all in one.
    So. Check valves, trust em enough to tile over?
    Jul 2009
    North Vancouver, BC
    I have never done so.
    I think you need to switch out the fixture. Sounds like forcing the design....
    Jan 2014
    Saskatchewan
    You make my wallet sad
    For what you want, a six way diverter. Not a three.
    http://www.deltafaucet.com/bath/details/r11000.html
  1. diverter value
    By bob444 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-20-2009, 09:55 AM
  2. Convert from valve diverter to spout diverter?
    By cnr1109 in forum Shower & bathtub Forum & Blog
    Last Post: 05-03-2008, 11:00 AM
  3. diverter valve leak - 3 valve diverter valve?
    By minillich in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-29-2007, 05:00 AM
  4. Diverter...again
    By Leigh in forum Shower & bathtub Forum & Blog
    Last Post: 07-10-2006, 08:12 AM
  5. 1 diverter or 2?
    By tameria11 in forum Shower & bathtub Forum & Blog
    Last Post: 12-24-2004, 06:19 AM
