Page 7 of 9 FirstFirst 123456789 LastLast
Results 91 to 105 of 121
Thread: Why does drywall work in a Kerdi Shower?
  1. #91
    Jul 2009
    North Vancouver, BC
    Default Spot setting is for hacks - so is drywall in the shower
    Post(s) deleted by John Whipple
  2. #92
    builder:anti-builder dhagin's Avatar
    Jan 2014
    oahu
    Since no one around here has ever seen or heard of a Kerdi Shower failure, a thread was started over at John Bridges site. All this talk of drywall failure as an academic exercise is all well and good, of course, but unless there are actual failures it's a solution lookin for a problem [that simply doesn't exist].
    Here's a link to the thread at John's site.
    http://www.johnbridge.com/vbulletin/...d.php?t=111300
    dana
    __________________________________________________ ______________________
    in my youth, i knew it all and treated folks like they knew nothing. after 3+ decades in the construction business, i came to realize that the more i learn, the less i know. now i treat folks as i want to be treated - with respect, no matter how little i know. :-)
    Note: please don't feed or quote trolls. thank you. :-)
  3. #93
    Jul 2009
    North Vancouver, BC
    Default Failing Kerdi Shower with Drywall and Spot Set Tile
  4. #94
    For those that aren't keeping up, the Kerdiboard failure was in a steam shower, likely where a steam line was too close to the board. The manual calls for a max temp around Kerdiboard of about 170-degrees (I'd have to look up the exact number, but that's close). Steam, boiling water, happens at 212-degrees at sea level. And, steam could be hotter than that once it is a gas, there's no practical limit on the temp it can raise. As far as I know, no final outcome on that situation.
    There's no evidence of an actual failure in the stone like shower shown, either. If that area is where the spray hits the wall, a natural stone can become saturated. There's no evidence that there is any leaks to the outside or structural failure.
    A foam Kerdi shower pan, if you read the instructions, says prior to installation, the floor must be level. Because you stand on the thing to embed it into the thinset, it is essentially impossible to try to level it with thinset and get a good bond to the substrate. Trying to level the pan afterwards is a very difficult thing to do, and the time involved and the reliability of the fix afterwards is beyond the scope of most DIY'ers, thus the recommendation to tear it out and start over.
    With the unprotected drywall, no question, that's just dumb. The difference is day and night. Done right, a Kerdi shower doesn't leak. Mold takes three things, eliminate any one, and it does not occur: moisture, food, mold spores. Kerdi, done right, eliminates moisture from anything behind it, and since it isn't food, nor is mortar or tile, mold will only happen if things aren't kept clean, and then on the surface...that can happen on ANY shower, regardless of how it is built.
  5. #95
    Jul 2009
    North Vancouver, BC
    Default Dry Wall and Kerdi Board - both bad choices for a shower
  6. #96
    Jul 2009
    North Vancouver, BC
    Default Drywall gets the thumbs down from TileLetter.com
  7. #97
    Jul 2009
    North Vancouver, BC
    Default John Bridge on why to use drywall in your shower build.
  8. #98
    Jan 2014
    oahu
    Lots of views over on JB's site, not a lot of talk about any failures....
    dana
  9. #99
    More pictures of tile directly on drywall...anyone that knows anything expects them to do nasty things if moisture is involved, but again, once covered with Kerdi, a waterproof material, it's no different than the drywall on your ceiling under your roof, or that on your walls next to the windows or doors. When installed properly as a system, the drywall never gets wet. http://www.schluter.com/media/shower...v=201401311539 I didn't make the recommendation up...Schluter did, and feels strongly enough about it to have had it tested and certified as waterproof by a well-respected testing agency, and backs it up with a decent warranty AND HAS BEEN DOING IT THIS WAY IN THE USA FOR DECADES. In the process, they also built waterproof showers with cbu and a few other materials, all called out in the referenced link, should you not trust yourself. But, if you didn't trust yourself to do it right, or don't want to read and understand their instructions, you may want to use a different material. A conventionally built shower can perform well, but loses the advantage of limiting any moisture to right under the tile like in a Kerdi shower. Lots more conventional showers can be found that have leaked if you look around than Kerdi ones, simply because it is not all that hard to build one that does not leak.
    Schluter is the only company with the long track record of successful showers done per their instructions (over 20-years), and believes enough in their product to safely make use of the less expensive, more easily installed material. The do not tell you you MUST use drywall, but that you can, and have a successful installation. Why spend money on extras when the success rate is identical, it goes up faster, and the end result comes out the same...a waterproof shower. I've said more than once, you do not have to use drywall in your shower when using Kerdi, but that you safely can if you are anywhere near a bit handy and can read and understand the pretty simple instructions and general guidelines on its use.
  10. #100
    Jul 2009
    North Vancouver, BC
    Default Drywall and a Failing Kerdi Shower
  11. #101
    A failing shower is one that leaks...there is no evidence that it is leaking. If that area is where the majority of the spray hits, it may just be that that tile is saturated, which is no reliable indication that there is a leak anywhere. Not all tile is equal, especially with natural stone.
  12. #102
    Not all waterproofing membranes are created equal , especially a sheet membrane -- Kerdi -- . Different rates of absorption and combine with the unmod mortar -- another thirsty one when dry -- , the drying time is ....like natural stone . Add a sealer on top of it , water will just accumulate .
    If leaks are the only thing that matter in a properly build shower , then I think the mirror is needed...........
    Roberto
  13. #103
    The Kerdi is waterproof. If that tile is hit by the concentrated shower spray on a regular basis, the tile itself could become saturated. If this were say a conventional shower with cbu behind it, it would wick water more, and a larger area would be wet. Some stone absorbs a fair amount of water, and it can take it weeks to dry out. The choice of the tile may be suspect, but it has nothing to do with whether the shower is defective from a functional viewpoint. All the membrane does is prevent moisture from getting behind it...what you put on top of it can get wet. With a dense porcelain, the tile would not change color. If the showerhead were moved a bit, that one may not get wet. It does not indicate a leak in the shower with the information provided.
  14. #104
    Jul 2009
    North Vancouver, BC
    Default I wonder if this is why spot setting tile is not allowed.
  15. #105
    I ........
    Attachment 23440
    Is sign drywall related?!LOL
    Roberto
  1. Another Kerdi Shower Question or two...
    By Lunker68 in forum Shower & bathtub Forum & Blog
    Last Post: 01-18-2013, 01:16 PM
  2. Kerdi Shower Question
    Last Post: 01-18-2013, 07:00 AM
  3. Can I Use Any Thin Set With Kerdi? The ICC-ES Evaluation Report On Kerdi Says You Can
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 01-08-2012, 10:19 AM
  4. A few questions before I get started on my Kerdi Shower
    By sdmarkus in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2010, 12:54 PM
  5. A newbie wants to build a Kerdi Shower!!
    By engrgrad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-09-2006, 09:49 AM
