Page 1 of 9 123456789 LastLast
Results 1 to 15 of 121
Thread: Why does drywall work in a Kerdi Shower?
    Default Why does drywall work in a Kerdi Shower?
    First, neither tile nor grout is totally waterproof, so whatever you use in a shower must not be damaged by moisture. Typically, people would use cement board on the walls with a vapor barrier behind it since none of those components are waterproof, BUT, none of them are damaged by being wet. The vapor barrier prevents any moisture trapped in those materials from being in contact with the wood studs and structure. The same thing is true on the floor of your shower...there's a waterproof layer preventing water from getting to it.
    So, it's not a long stretch to realize that if you do put drywall in a shower, if must be kept from ever getting wet or you'll have problems. This is exactly what the Kerdi membrane does...it is a very effective waterproofing layer. Just like the liner in your shower keeps the wooden subfloor from rotting out or ever getting wet, the membrane does it for not only the walls but the floor. So, if you built it properly - the drywall stays dry, the floor stays dry, and everything works out well.
    As with anything, if you make a mistake or breech the waterproof layer, you'll have problems. But, after installation and a flood test, the entire surface is covered with tile, so that layer remains well protected, and is easily able to do its job.
    Some related concepts: why can you use wood underneath your roofing shingles? Because when properly installed, the roof doesn't leak. Why can you use drywall on the inside walls next to your windows? Because a properly installed window doesn't leak. Sure, you can break the window or have wind blow a shingle off, but that's hardly likely to happen inside of a properly built shower covered in tile!
    Schluter has ben using Kerdi over drywall for decades, and since the certification doesn't last forever, has been getting it retested to reverify it still works to stay in compliance bi-annually. The ICC (International Code Council) test report ESR-2467 covers the certification for both Ditra and Kerdi and is only valid if you follow the manufacturer's installation instructions. While other methods might work over drywall, to my knowledge, none have the history or the certification, or test data to show that they work properly in that environment. So, do not take Schluter's experience with Kerdi make you think that another system is certified, tested, and warranted in other than their tested, approved substrates.
    FWIW, that report is valid over the following surfaces in a shower (from section 2.0):
    "Kerdi is intended for use on floors over concrete, mortar and tile backerboard substrates. Kerdi is also used as shower lining, as required in IRC Section P2709.2 and IPC Section 417.5.2, over concrete, mortar, tile backerboard, expanded polystyrene foam board, prefabricated polystyrene shower trays, curb and ramp, gypsum board and masonry substrates."
    So, you can choose what board you want in your shower when using Kerdi. Schluter's recommendation is drywall since it is available in larger sheets so you have fewer seams, accepts thinset well, and allows excess moisture from the thinset to be purged while maintaining a suitable environment for the thinset to cure and attain its best strength.
    Kerdi will work equally well with any of the approved substrates - choose the one you want, install it per the manufacturer's instructions and you'll have a long-lasting, problem-free shower. Don't let any nay-sayers force you into any other extra steps by making you feel guilty...IF you do it right, it will not leak. IF it does, fix it before you put up your tile. Based on the certification, doing it otherwise could void the warranty and the certification of the Building Codes.
    builder:anti-builder dhagin's Avatar
    Jan 2014
    oahu
    Yep, pretty much sums it up.
    For even more info, see the "Schluter - Shower System Installation Handbook".
    http://www.schluter.com/media/shower...v=201401250602
    dana
    __________________________________________________ ______________________
    in my youth, i knew it all and treated folks like they knew nothing. after 3+ decades in the construction business, i came to realize that the more i learn, the less i know. now i treat folks as i want to be treated - with respect, no matter how little i know. :-)
    Note: please don't feed or quote trolls. thank you. :-)
    If we have to look at an engineering POV , using the drywall in showers or wet areas is a no-no . The codes are a minimum -- repeat a minimum -- of building procedures to respect . Kinda strange to see you coming so strong with it as a recommendation .
    Drywall compared with plywood is by far an inferior product . And talking about roof leaks -- most of the showers are build under roofs -- , if the tiled ceiling gets wet , the drywall will collapse . If the walls are getting wet ...
    Quote :
    " Moisture Movement (Wicking) within Gypsum Wallboard
    Paper # 580
    Dale J Greenwell and Marc Y Menetrez
    US Environmental Protection Agency, 109 T.W. Alexander Drive, Research Triangle Park, NC
    27711
    ABSTRACT
    Gypsum wallboard with repeated or prolonged exposure to water or excess moisture can lose
    its structural integrity and provide a growth medium for biological contaminants. Poorly sealed
    buildings, leaking or failed plumbing systems, or improperly constructed HVAC systems can all
    contribute to water and moisture problems. Gypsum wallboard readily absorbs moisture through
    direct contact with standing water and differences in water vapor pressure. Regular gypsum
    wallboard sample sections were hung vertically and exposed to a continuous source of standing
    water 1.3 cm in depth. Both water absorption (measured in percent moisture content) and
    vertical movement (wicking height) were monitored within the wallboard over several days. The
    moisture content measurements revealed a water movement pattern similar to paper
    chromatography. A leading edge of relative high percent moisture content (~ 20%MC) moved
    upward along the width of the wallboard. The immersed portion of the wallboard maintained a
    moisture content level ≥ 20%. Between the leading edge and immersed portion of the wallboard
    was an area of moderate moisture content (~ 12%MC). Water wicked to a height of 15 cm
    within the first three hours of testing after which the rate continued asymptotically appearing to
    reach a maximum height by day 16.
    IMPLICATIONS
    Most wallboard remediation techniques involve visual inspection and moisture content
    measurements to determine the extent of the water damage and the presence of or potential for
    mold growth. Remediation not performed within a reasonable time following discovery, may
    result in ineffective remediation as moisture may continue to move beyond the original detected
    region. Because of the wide spread used of gypsum wallboard in commercial and residential
    construction, understanding the moisture movement (wicking) of water in gypsum wallboard
    products is essential. ''
    End quote .
    If you want to rely only on the membrane -- Kerdi or similar -- for waterproofing and not consider the safety of the assembly , I think you are doing a good job .
    Roberto
    No argument that when drywall gets wet, it loses integrity. But, it is no more likely to get wet in a properly built Kerdi shower than it is on the ceiling under a solid roof or next to a window or a door. The point being - Kerdi is proven waterproof when installed properly. Therefore, any tested and approved material used underneath it can produce a reliable, long-lasting shower. Use any one of the approved materials and it still works fine. When installed properly, the only way drywall (gypsum board) will get wet is from some other way, and that's not a problem with the shower build.
    Once the shower is flood tested, then covered with tile, it is going to take some other fault in the house for it to cause a problem in the shower. I don't have any issue about which substrate you end up deciding to use, I have an objection to the years of test data that says it works, passes building codes, and is warranted by the manufacturer that has a vested interest in it working being touted as wrong.
    Just in case the roof leaked, do you put CBU on the ceiling? What about next to a window or a door? No, you accept that whoever put the roof up or the door or window in did it properly, and if you have a fault, you fix it.
    If you're really paranoid, you could make your house entirely out of cement, stone, and tile...then, if it got wet because of some misstep, you'd just mop up.
    All of this coming from an engineer .........surprising.
    I guess you are working only on the membrane level and the rest is not important . Drywall , like other products, are only accepted by Schluter for a shower installation . None of the drywall mfgs recommends the use of drywall in wet areas.
    I guess long lasting is less important than your coating of inferior products. Reminds me of the arguments that drywall contribute to increase the structural #s when calculate them . Probably they will also accept an inferior product saying that if everything else is done right , the walls will not buckle. Such a mediocrecy .
    Roberto
    Jul 2009
    North Vancouver, BC
    Post(s) deleted by John Whipple
    Jul 2009
    North Vancouver, BC
    Default Dry Wall and Kerdi - Jim's first discussion start of 2014
    Jul 2009
    North Vancouver, BC
    Default Dry Wall is crap
    What happens to the wooden structure of the room when a shower pan leaks? The subfloor rots, the floor plate rots, the studs and maybe the joists rot.
    If we trust Kerdi to protect the floor from getting wet, why can't you trust it to protect the walls?
    Millions of square feet of tile has been successfully installed on drywall, so the bond to that substrate is a known thing.
    If you believe Kerdi is waterproof, tests have shown it to be, why would you believe it can work as a pan liner and not also protect the walls it is installed on?
    Agreed, drywall in a conventional shower is stupid. A Kerdi shower is no more a conventional shower than a salt crystal is a diamond.
    If you don't trust yourself to install Kerdi properly, like apparently John Whipple, you use all of the extras you can think of to patch it and provide secondary layers of protection. Most people believe their roof will keep the house dry, the windows will keep out the rain, as will the doors when properly installed. People don't give a second thought to the use of drywall underneath the roof - look at the millions of square feet of cathedral ceilings, or the millions of homes with drywall next to the windows and doors.
    It is not such a great leap to believe that neither the walls nor the floor of a properly built Kerdi shower will ever get wet. If it did fail, regardless of the materials, it won't make a difference what's there...you'd have to tear it out and repair it. So, build it right the first time...it works.
    Quote Originally Posted by eurob View Post
    Explain to me why if Kerdi works as a pan liner, and one does not consider the subfloor under a shower a wet area, why is drywall behind a waterproof membrane that has been tested and approved for use in a shower, that drywall is in a wet area?
    The whole point of this is that when installed properly, NOTHING on the other side of Kerdi is in a wet area.
    If you do not believe Kerdi is waterproof, why would you ever use it as a pan liner?
    Mar 2011
    Houston, TX
    You guys Crack me up.
    You are good Free Entertainment.
    They use Drywall in Shower stalls here in my location. I do not know enough about to tell if it is right or wrong.
    The inspectors must see it as OK.
    Your Location may very.
    There are not many locations around the Coast here, where it is not a damp location. Dry wall works just fine.
    Keep it coming Guys, I get a kick out of the entertainment that you provide.
    Have Fun Everyone.
    Quote Originally Posted by johnfrwhipple View Post
    I know it's wrong and the only reference you can hang on to is that Schluter says it's OK.
    Do you not put any credibility to the ICC? If when they tested if it failed, would they risk their standing and reputation? What about the hundreds of thousands of Kerdi showers that have been built that don't leak? ANY shower can fail if there are workmanship problems, and if it does, it really doesn't matter what's behind the waterproofing...it has to come out to be fixed.
    Massachusetts requires any plumbing work to only use approved materials and methods - they list Kerdi, the Kerdi drain in their database WHEN INSTALLED PER THE MANUFACTURER'S INSTRUCTIONS. They do not, the last time I looked, exclude or make exceptions for the use of drywall in that install. http://license.reg.state.ma.us/pubLi...tion=&psize=50 This is just one example...
    DIY Senior Member DougB's Avatar
    Jun 2010
    Minneapolis - Land of 10,000 taxes
    As an engineer (I don't think that matters), and as a pratical person, I can't for the life of me understand why someone would usee drywall in a shower! If you had just a teeny tiny leak - the drywall is going to go to shit. Cement board could tolerate it, and maybe with no ill effects.
    What do you save by using drywall? $50? Why risk it? What's the point? Because it can be done?
    If a fixture would leak behind the drywall - you would be sunk.
    I would say using drywall in a wet area: safety factor = 0.9
    If a hammer won't fix it, it's an electrical problem.
    Notice that the original title says why you CAN use it in a shower...it doesn't say you HAVE to...
    But, why? For the same reasons I do not worry about drywall on my ceiling, or next to my doors or windows. A leak there will have the same effect-tear out and fix. But, I've lived in this place for nearly 30-years, and I've never had to replace any drywall because of water leaks through the roof or from around windows or doors. Drywall is readily available in bigger sheets, cuts easily without carcinogenic dust so it has fewer joints that have to be supported with blocking, unlike the typical 3x5' sheets of cbu (yes, you can special order bigger sheets, but then try to get them to the job site unbroken and then you still have to lift them!). Over those 30-years, I've not had a water supply pipe fail where it leaked and caused damage. Why would you expect it to do it in your shower? There are seals made for protecting any penetrations through the Kerdi membrane for around things like the shower arm, and valves. Or, KerdiFix works, too. There is no reason why the drywall behind the shower wall is any more likely to get wet than in the rest of the house IF you build it properly.
    Jan 2014
    oahu
    Ain't gonna get in a pissin match with you fellas, but drywall and other gypsum boards, as a backer, have been used successfully in showers since it came out. See: mud shower. Mud showers with asphalt impregnated building paper, or plastic over the drywall work just fine and have since before I was born, over 50 years ago.
    Schluter has a proprietary system that has been tested to meet or exceed industry standards. Plain fact is, their system works. You wanna not trust the manufacturer or industry who approves their products for their intended uses, when there are successful installs over drywall functioning just fine for many years out there, that's certainly your prerogative.
    dana
  1. Another Kerdi Shower Question or two...
    By Lunker68 in forum Shower & bathtub Forum & Blog
    Last Post: 01-18-2013, 01:16 PM
  2. Kerdi Shower Question
    Last Post: 01-18-2013, 07:00 AM
  3. Can I Use Any Thin Set With Kerdi? The ICC-ES Evaluation Report On Kerdi Says You Can
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 01-08-2012, 10:19 AM
  4. A few questions before I get started on my Kerdi Shower
    By sdmarkus in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2010, 12:54 PM
  5. A newbie wants to build a Kerdi Shower!!
    By engrgrad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-09-2006, 09:49 AM
