Results 1 to 8 of 8
Thread: Popup drain leaked on first test
    DIY Junior Member Elijahwww's Avatar
    Jan 2014
    MA
    Default Popup drain leaked on first test
    I installed a set of Danze faucets in my new bathroom vanity, but the metal drain is leaking on both sinks. It is leaking from either the tailpipe where it is threaded into drain collar or from the collar itself, I can not tell.
    The collar came with rubber washer on top and bottom, so i did not use silicone or putty.
    For the tailpipe I used about a foot of teflon tape.
    The picture below doesn't show the top rubber gasket that goes under the flange, but the unit came with it.
    What did I do wrong?
    http://www.danze.com/file.aspx?DocumentId=299
    DIY Member ImOld's Avatar
    Jun 2013
    In the rumble seat
    I don't see anything about
    in the instructions.
    Is that a good enough hint for you?
    If you used that much tape, I don't know how you even got the thread to start much less tighten up.
    Jan 2008
    Some plumbers putty on the threads before you tighten the tailpiece should do the trick.
    Either pipe dope or plumbers putting on the threads of the drain collar. None on the rubber donut below the sink.
    The tail piece either gets pipe dope or a little tape.
    I have never seen instructions with faucets mention this, but it keeps us employed.
    Jan 2014
    MA
    Thank you all. I will try the putty next.
    HJ, the threads had that much slack, that I made 3 rounds of tape and i could still thread it with relative ease.
    Jan 2014
    MA
    That worked, plus more putty on the drain collar threads, where-about the bottom rubber washer is. It wasnt keeping the seal otherwise.
    Is there a safe torque spec for the lock nut? I was afraid of cracking the sink or bending the flange.
    Jan 2014
    MA
    Still no leaks, thanks everyone
  1. two faucets one drain sink...can i use faucets with standard popup drain?
    By naadimre in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-11-2013, 09:10 AM
  2. Repairing/refinishing a leaked-on ceiling
    By Mikey in forum Remodel Forum & Blog
    Last Post: 03-18-2008, 10:59 AM
  3. Popup drain plug doesn't
    By ToolsRMe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2006, 05:00 AM
  4. Non-removeable lavatory drain popup
    By smhowell in forum Remodel Forum & Blog
    Last Post: 08-17-2005, 07:00 PM
  5. Kohler Bath Drain Popup Stuck HELP :-(
    By Michael Roback in forum Shower & bathtub Forum & Blog
    Last Post: 02-21-2005, 01:31 PM
