Results 1 to 9 of 9
Thread: Kitchen sink drain leaks when emptying full sink
    DIY Junior Member queen50's Avatar
    Mar 2012
    Washington state
    Default Kitchen sink drain leaks when emptying full sink
    We have a double sink. One sink works fine, but the other drain leaks if the sink is full of water when the stopper is pulled. I can see it dripping from the bottom of the P-trap, but can't pinpoint where the water is coming from. It works fine with simply running water, or if it contains a smaller volume.
    I should add the plumbing has worked fine for 20+ years; this is a recent development. Any ideas of what I should look for?
    Sep 2013
    Tie a cloth or cotton rope around the tailpiece (the top vertical pipe). If that gets wet, the problem is at the top of the tailpiece. If not, the problem joint is below that.
    There are several places it could leak, but we would have to be there to tell you which one is your problem. It is illogical to assume that a single trap will only leak when one of the sinks drains, but not the other.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Can't pin point the leak? worked fine for 20 years?
    I'd replace or re-do the drain set, from the bottom of the sink to the trap.
    Mar 2012
    Washington state
    Each sink has its own P-trap. I meant to say that the identical setup is working fine.
    Mar 2012
    Washington state
    Quote Originally Posted by Reach4 View Post
    I put a cloth around the tailpiece just above the connection to the P-trap; it got soaked. That means the drain assembly needs to be replaced?
    DIY Member ankhseeker's Avatar
    Oct 2013
    California
    Maybe you could add some food coloring to the water to help locate the source of the leak. Might show up better on a rag wrapped around the pipe.
    Quote Originally Posted by queen50 View Post
    An easy fix it to replace the basket.
    That way you get a new tailpiece washer with it. I like to replace baskets every so often anyway. They tend to lose the chrome finish after a few years.
    Mar 2012
    Washington state
    I will try this. Thanks!
  1. Kitchen Sink Strainer Leaks
    By Norm R in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2013, 07:36 PM
  2. Sink drain locknut leaks
    By wildpack in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-18-2011, 08:11 AM
  3. kitchen sink: trying to find off center drain undermount sink
    By belzoid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-29-2010, 06:00 PM
  4. Water shut off valve leaks under kitchen sink
    By ryan_siefring23 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2008, 06:48 PM
  5. kitchen sink drain is lower than waste pipe and leaks
    By lafk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-08-2007, 10:55 AM
