Results 1 to 5 of 5
Thread: Replacing light switch with a Timer that has an extra Red Wire.
    DoD Army bjferri's Avatar
    Jun 2007
    Maryland
    Default Replacing light switch with a Timer that has an extra Red Wire.
    I opened up the electrical box that has 3 light switches. So, I have the white cluster of wires all bundled up, same with the black, same with the ground. The light switch has the ground and 2 blacks (top "on" and bottom "off") so I'm assuming the bottom is hot and the top the load. My questions is: Where do I make the Red wire connection from the timer?
    Brian
    Jan 2008
    It came with no instructions? A timer would need hot and neutral to power itself. The red is likely for the load. Given that we have the internet, manufacturer's instructions should not be hard to find.
    Jun 2007
    Maryland
    Thanks. It came with Instructions albeit slightly ambiguous. I figured the Red was for the Load, Black for Hot, etc.
    Question. That switch I'm replacing has the Hot at the Top, with the Load at the bottom. The other switches in the Box have Hot on bottom and Load at Top. I'm confused with Hot on top...?
    Brian
    DIY Member ankhseeker's Avatar
    Oct 2013
    California
    It might also be a 3 way switch? BAC are there 2 switches to operate that light?
    Jun 2007
    Maryland
    It's not a 3 way switch but it does control 2 outside lights.
    Brian
  1. 3 way timer switch
    By lambed3 in forum Electrical Forum discussion & Blog
    Last Post: 08-05-2012, 10:51 PM
  2. I need a timer for a bathroom fan/light/heater combo.
    By Erico in forum Electrical Forum discussion & Blog
    Last Post: 01-24-2012, 08:44 PM
  3. Extra circulator pump. How do I wire it?
    By jdshopping in forum Boiler Forum
    Last Post: 12-31-2010, 03:16 PM
  4. DIY - Split receptacle to light switch and light fixture with 14/2?
    By AJM in forum Electrical Forum discussion & Blog
    Last Post: 11-24-2009, 04:36 PM
  5. fluorescent light bulb's don't work with Timer's?
    By bjferri in forum Electrical Forum discussion & Blog
    Last Post: 06-03-2008, 07:49 PM
