Results 1 to 3 of 3
Thread: Double Fixture cross Usage with an Immediate horizontal turn
    DIY Junior Member KenLewie's Avatar
    Jan 2014
    Minnesota
    Default Double Fixture cross Usage with an Immediate horizontal turn
    Hello,
    I'm a G.C. doing a kitchen and bath remodel in a very old home. My plumber (who I have not worked with before) tells me that this will be ok. I know he is gonna have to ask the inspector anyway but I want to start framing for the changes ASAP. I originally suggested leaving out the jog and making the pipe look like a post when it goes by the kitchen island. The homeowner would rather not have the fake post with a plumbing pipe in it next to an eating area. So the plumber is suggesting this jog around the island where it can be buried into a wall. What say you all? Thanks for you time and consideration.
    The jog is fine.
    If you ever replace those toilets, and they have 3" flush valves in the tank, the water will skip across the fixture fitting and push a bit of water out of the opposing bowl.
    It's not too bad. At least you don't have a double santee there.
    Jan 2014
    Minnesota
    Thanks for the feedback Terry!!! Great site you have hear. I will keep the 3" flush valve in mind. Would it make much difference to use a combo double Y with 1/8 bends rather than the Double fixture fitting. I believe there is room since both toilets are 18" from the wall to their sides?
  1. Double Combination Tee-Wye (Horizontal)
    By RockRiverShooter in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-04-2013, 06:21 AM
  2. Converting to double sink-drain pipe too close to stud for double fixture fitting.
    By Finch85 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-11-2012, 06:04 PM
  3. Double Elbow in Horizontal?
    By mhw in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-22-2011, 09:55 PM
  4. Double fixture tee or double sanitary tee?
    By nc8861 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-03-2011, 11:33 AM
  5. Source for double fixture cross?
    By lojoma in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-31-2009, 03:55 PM
