Results 1 to 7 of 7
Thread: Is high efficiency boiler worth extra $4,000?
    Default Is high efficiency boiler worth extra $4,000?
    Friend building a new house (around 6,000 sqft). He is deciding between standard 85% efficiency boiler vs. the 95% high efficiency. Upcharge is about $4,000.
    Doing radiant in some of the house and then whole house is hydrocoil. Contract calls for 2 boilers, 180,000 BTUs each. That's the 85% ones. The 95% would be a weil-mclain ultra 3, 95% efficiency, one boiler (assuming the same 360,000 BTUs).
    He'll have approx 9-10 zones, including the 120-gallon storage tank.
    Any advice?
    Thanks.
    Nov 2010
    Maine
    10% difference times the amount and cost of the fuel uses. Do the math.
    Lets say the cost of operating the 85% boiler for a year is 800 bucks
    So the 95% efficient boiler is going to cost 80 bucks a year less to operate
    divide that 4 grand up charge by 80 and you get.......a 50 year payback ratio.
    Of course the boiler will either crap out or be yesterdays news or you will be dead by then.
    The big problem here is that even though 6000 sq/ft is a big assed house, unless it is 95% glass and uninsulated it ain't going to need anywhere near 360 thousand BTU/HR to heat it. Who did the heat loss?
    In the trades Dana's Avatar
    Jan 2009
    As Tom correctly points out, two 180,000 BTU/hr boilers for a 6000' house is a ridiculous amount of oversizing even for a sub-code house, let alone a new code-min house. Seriously, 360,000BTU/hr is is 60 BTU/hr per foot of conditioned space, a ratio that would make sense only for barely-insulated 2x4 house in Fairbanks AK.
    Also 10 zones on 360KBTU/hr of boiler is guaranteed to short-cycle the hell out of those boilers, cutting into both lifespan and efficiency, independently of their AFUE rating. Even a 120gallon buffer tank won't necessarily save you with 360K of burner driving it.
    The first order of business is to get a credible room-by-room/zone-by-zone heat load calculation. Most code-min 6000 houses these days can be successfully heated at 0F outdoor temps with a single 100,000 BTU/hr boiler.
    What fuel?
    Got a ZIP code? (For outdoor design temp purposes.)
    How is the hot water being heated, and are there any big spa tubs or luxury 6 side-spray gusher showers to tell us about?
    DIY Member Soapm's Avatar
    Dec 2013
    Aurora, CO
    Quote Originally Posted by davidwie View Post
    Any advice?
    Thanks.
    Sorry to chime in but I love reading these guys advice, and it seems the best advice is change contractor or installer... ROFL...
    Are they planning snowmelt on a long driveway or big parking lot? That's some serious amount of heat. Now, this is probably 5-6 years ago, when I was looking at boilers, I was looking at a WM and some other boilers...while the place I ended up buying mine from had installed some of those, he refused saying they had too many problems. I ended up with a Buderus unit. No personal experience with WM, and even if they had had teething problems with that model, I'd expect they'd have fixed them by now. The brand has some importance, but the quality of the installer is probably more important. An overly large unit usually won't meet its energy efficiency rating.
    Jan 2009
    Quote Originally Posted by Soapm View Post
    My advice itends toward doing at least the napkin-level math yourself, then either make the contractor show his or make them do it your way if it diverges by a huge amount. Not all plumbers are competent hydronic designers, even if they have some experience at installing the equipment. It's possible to do a good job at the installation, even if clueless as to how to spec the equipment (and conversely.) This one really screams for a design review by a competent designer, even if he sticks with the contractor for the installation. With a dozen zones and two boilers it's gonna take a pretty big napkin to put arithmetic bounds on all of it.
    Nov 2010
    Maine
    With a dozen zones and was it two boilers? I want to be the guy that sells and installs it even if it is oversized and way more complicated than it needs to be. I have a kid going to MIT next fall, I need the cash LOL
  1. pH neutralizing media on high efficiency boiler
    By nestork in forum Boiler Forum
    Last Post: 08-25-2012, 09:15 PM
  2. Is a super high efficiency boiler worth the inital cost?
    By jadnashua in forum Solar and Geothermal Water Heating Forum
    Last Post: 04-23-2009, 10:41 AM
  3. Is a super high efficiency boiler worth the inital cost?
    By jadnashua in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-15-2008, 05:09 AM
  4. Budgeting the installation of a high efficiency gas boiler in Boston
    By milesjamie in forum HVAC Heating & Cooling
    Last Post: 03-06-2008, 06:44 AM
  5. Need extra high toilet for extra tall husband
    By sweetswededoc in forum Toilet Forum discussions
    Last Post: 11-20-2006, 04:18 AM
