Results 1 to 9 of 9
Thread: Tub Drain & Overflow Styles
    Default Tub Drain & Overflow Styles
    I have noticed that there are generally two styles of tub D&Os. The most common puts the p-trap under the overflow pipe and the less common has the p-trap directly under the drain. I've included two images to illustrate my words if they aren't clear.
    p-trap under overflow pipe:
    p-trap under drain pipe:
    Name:  Under Drain.jpg
    The latter seems to be more common in the UK.
    Are there any clear advantages / disadvantages or code issues between these two styles?
    Louis
    Plumbing Code is okay with either configeration.
    They may not allow slip joints in concealed places though. Many of our installs now use solvent weld joints.
    Either ABS or PVC
    Either ABS or PVC
    Are you saying this is more of an issue with one design or the other?
    This is a remodel situation. I've stripped down to the studs and floor joists. Installing the D&O on the tub might be a challenge since I don't currently have access from below - would require ripping out some sheet rock, which I might do.
    I plan to use PVC fittings. These pictures were just for illustration. I believe both designs are available in PVC.
    Louis
    Nov 2009
    Victor, MT
    Whichever setup is easiest is best. I would stay away from cable operated stoppers, you can count on them to fail.
    Quote Originally Posted by asktom View Post
    What type of stoppers do you prefer?
    The building consruction will determine which one fits, depending on the joist locations. The "toe outlet"/ second one requires a very precise trap location, while the heel outlet has more "adjustment' possibilities. There is a third option where the tee is on it back and the outlet is horizontal.
    hj,
    Thanks for the name, "toe outlet". Helps to get the nomenclature right. This is what I had before I ripped it all out but I can see that replacing with the same configuration could be harder without removing the sheet rock below, which I might do anyway because of some past water damage causing a bit of sag.
    I don't believe my joists will be an issue for either type. They run the length of the tub.
    Louis
    If joists are NOT a problem, then there is absolutely NO reason to use the toe outlet, given that it is much more difficult to position the trap EXACTLY below the tub drain outlet.
    Perfect. Exactly what I needed to know.
  1. Bathtub Drain/Overflow Connection to Cast Iron Drain Pipe
    By darylm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-04-2012, 03:38 PM
  2. Better Life Styles Inc, toilets that are vented
    By Terry in forum Toilet Forum discussions
    Last Post: 05-04-2010, 10:58 AM
  3. using an overflow drain with a non-overflow sink?
    By chelsea in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-09-2008, 06:19 PM
  4. Help! - New Dishwasher Styles
    By JackScrap in forum Remodel Forum & Blog
    Last Post: 06-19-2007, 11:36 AM
  5. Wax Free Toilet Seals - different mfgs/styles
    By KBradley in forum Toilet Forum discussions
    Last Post: 08-11-2005, 06:57 PM
