Results 1 to 2 of 2
Thread: No hot water
    DIY Junior Member Brian Dittmar's Avatar
    Jan 2014
    CT
    Default No hot water
    Need some advice. Have an oil fired buderus boiler and an indirect dhw tank. System has been acting funny with zone panel set on hot water priority. So I shut that off and hot water would run out but would recover fairly quickly. Now tonight, no hot water. Any thoughts?? Thanks
    In the trades Dana's Avatar
    Jan 2009
    Depends on what you mean by "acting funny". Even with priority off it should still heat the tank when the tank is calling for heat. If the aquastat on the indirect (or it's wiring connections) are flaky, or those of it's zone pump, you could have intermittent performance, eventually leading to none. But a better description of the "funny" behavior might provide more insights.
