Results 1 to 4 of 4
Thread: Water heaters in series
    DIY Junior Member Jbel's Avatar
    Jan 2014
    Lima, NY
    Default Water heaters in series
    I'm thinking about installing a second water heater in series with my existing tank. Could someone tell me where the expansion tank should be located, or if I even need one? I have one 40gal electric heater and want to add another 40 gal.
    DIY Senior Member JerryR's Avatar
    Jul 2011
    Florida
    Expansion tank can be installed anywhere in the house, on a cold water line. The majority are installed at or near the hot water heater cold water inlet side.
    If you have a closed system heater manufactures and or code requires on. A closed system is where you have either a check valve, PRV or a backflow device installed.
    JR
    Jan 2014
    Lima, NY
    My home is an old farm house. I just purchased it. It has well water as a source. So far I have a sediment filter before the expansion tank which then goes into my Hague purification and softening system then out to the house. I've switched most of the home over to pex. Will the original pressure tank for the system suffice?
    If there are no check valves between the water heater and the expansion tank, you would be fine.
  1. 2 water heaters, series or parallel??
    By macingrace in forum Water Heater Forum, Tanks
    Last Post: 12-11-2012, 03:11 PM
  2. Replacing a Delta 1300 series with a 1700 series
    By desvio in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2011, 06:42 AM
  3. Series Hot Water Heater
    By coreground in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-04-2007, 10:42 PM
  4. water heaters in series
    By canton in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2006, 06:33 PM
  5. Water heaters in series
    By jimmym in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2006, 05:28 AM
