Results 1 to 5 of 5
Thread: vent well to release sulfur gas
    DIY Junior Member nepsa's Avatar
    Jan 2014
    Virginia
    Default vent well to release sulfur gas
    had a new drilled well of 420 ft. After 6 months, i have a sulfur smell in water. I replaced the hot water tank and added a zinc anode rod. helped, but did not correct the problem all the way. I have a 1/2 plug on the well top that i can use to vent sulfur gas. first, will that help and if it will, what is the best vent for a 1/2 inch plug. I have seen pictures of some are straight up like a pencil and others have a bend at the top like the end of a walking cane. any suggestions. Also, i have a septic tank, so i understand shocking could be a issue.
    thanks
    nepsa
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by nepsa View Post
    There is no reason to send it all to the septic tank. Also, raising the temperature of the HWT can help if it is just the hot water that smells.
    Galvanized tanks with airmakers (snifter/bleeder/check) are often used to aerate smelly water.
    Jan 2014
    Virginia
    Thanks, I am hoping that someone has some information on the best vent to use on 1/2 hole at the well.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Here is a vent that is a section of pipe with slits in the side. It lets air in or out but does not let bugs get in.
    http://www.completeplumbingsource.co...stic-well-vent
    Here is a link to a well vent that is a section of pipe with two 90 degree bends. There is a screen over the end of the pipe.
    http://www.soil.ncsu.edu/publication...massist/water/
    I see both types of well vents. I do not think it makes a difference. If your well does not have a vent and there is a space for one, it will not hurt to add one. I do not think is will help much with venting the hydrogen sulfide gas in your well.
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    This might be a good application for the "Sulfur Eliminator".
    http://www.wellwaterstinks.com/
  1. Hot water release valve running 24/7
    By ChesterW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-07-2013, 06:07 AM
  2. how do I release the flange?
    By timbo69 in forum Toilet Forum discussions
    Last Post: 09-21-2009, 06:35 PM
  3. Release Valve leaking??
    By gtjr921 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-14-2008, 10:23 AM
  4. Leaking Presure release valve
    By devans175 in forum HVAC Heating & Cooling
    Last Post: 02-20-2008, 09:32 AM
  5. Is this a pressure release valve?
    By craniac in forum Irrigation / Sprinkler Forum
    Last Post: 05-12-2007, 08:08 PM
