Results 1 to 7 of 7
Thread: Penetrating a brick wall with 4" pvc
    DIY Senior Member jim mills's Avatar
    Jan 2014
    nebraska
    Default Penetrating a brick wall with 4" pvc
    I just replaced some rusted out cast iron with PVC. The pipe penetrated a stone foundation wall into a crawl space. The cast had mortar around it to seal the penetration, but I had to chip it away because the PVC was slightly larger. I have plenty of clearance for the PVC, but how should I seal the penetration now?
    Maybe some spray foam? Hydraulic cement would seal it, but since pvc expands and contracts a lot, not sure that would be a great idea.
    Jan 2014
    nebraska
    I was thinking spray foam as well, but thought it would look "un-professional".
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    In the trades Dana's Avatar
    Jan 2009
    Mortar in around one side with a standard mortar-mix, then a healthy bead of "Windows & Doors" type can foam for the weather seal. which is far more flexible than the standard polyurethane can foams. If it has to look good on both sides, only fill about 1/4 of the depth with the expanding foam, and if begins to poke out as it cures, push it back in sufficiently to give you a half-inch to an inch for mortaring up the second side. Over time & temperature you may eventually see a thin separation between the mortar & PVC, but the flexible can-foam will maintain the air seal.
    Jan 2014
    nebraska
    Thanks Dana, that's probably about as good a method as can be described.
    I believe that IRC states that a PVC pipe must be sleeved if passing through a brick wall.
  1. Hit a brick wall...could really use some advice
    By jeremytl in forum Remodel Forum & Blog
    Last Post: 04-21-2012, 08:54 AM
  2. Hiding cables behind a brick wall
    By funperro in forum Remodel Forum & Blog
    Last Post: 08-03-2011, 07:48 AM
  3. New exterior receptacle in old brick wall
    By TJanak in forum Electrical Forum discussion & Blog
    Last Post: 02-01-2010, 07:49 PM
  4. How can a drain pipe in a brick wall be repaired?
    By Onlooker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2009, 05:58 PM
  5. Leak inside brick wall from outside spigot
    By Jan Salazar in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2008, 06:41 PM
