Results 1 to 3 of 3
Thread: Triangle Challenger noise when starting up and shutting down
    DIY Junior Member Kidj00's Avatar
    Jan 2014
    Default Triangle Challenger noise when starting up and shutting down
    Boiler has been in service for about 3 months and now when it starts up and shuts down there is a snapping or clicking noise which seems to be at the top of the unit. Do you have any ideas what this could be?
    It could be the exhaust/intake pipes. If things have slightly shifted, and those pipes run through anything that got tight, as the temp changes, they expand or contract, and if 'caught' on anything, they can easily make clicking sounds. The same thing happens with plastic drain pipes as you say run a shower - you don't normally hear it while showering, but afterwards, as they cool off, it is not uncommon to hear them. The prevention is properly sized holes, and proper support. Harder to fix afterwards.
    Jan 2014
    It doesn't sound like it is in any of the piping if you are talking about the PVC. It sounds as if it is by the burner assembly itself. It has been making this sound for a week now.
  1. Triangle Tube Challenger 105 DHW problem
    By emd36 in forum Boiler Forum
    Last Post: 11-12-2013, 08:04 PM
  2. Challenger PC266R pressure tank
    By Gpace1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-24-2013, 06:37 PM
  3. triangle tube prestige 110
    By mark161 in forum Boiler Forum
    Last Post: 02-09-2013, 04:02 AM
  4. Flexcon Challenger tank moved slightly
    By Flawell in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-05-2012, 10:41 PM
  5. Odd Noise Like Water Shutting Off
    By jmcre8 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2006, 01:38 PM
