Results 1 to 6 of 6
Thread: Black on Cold Water Line
    DIY Junior Member KCinToonTown's Avatar
    Jan 2014
    Alberta
    Default Black on Cold Water Line
    The picture shows three plumbing pipes that I uncovered when I tore off drywall as part of a kitchen remodel. The left pipe is the 3" drain from the second floor, the right line (next stud cavity) is hot water up to the second floor (3/4") and the middle one is COLD up to the second floor (also 3/4"). It is the cold water line that intrigues/concerns me.
    It is the only section of copper in the house that I've found with these black deposits on it.
    I've been searching the internet and it seems to get blamed on drywall or pipe imported from overseas, but given that the two pipes shown likely came from the same supply, and had the same drywall over it (sheets were installed horizontally, no seam between these two cavities) I can't accept that these could be an issue.
    I've also looked at the copper in the joist cavities in the basement and it doesn't seem to extend below the floor (difficult to see because of basement finishing), but on the second floor the bit I can see under the two closest sinks (Mstr Bath) do show the black deposits (just the cold again). The 1/2" projections to the toilets look more 'normal'.
    You may have noticed a hole in the bottom plate in the same cavity as the problem pipe. There was a plug for the fridge located just above where the picture ends (removed as cabinets are going in here). Additionally, the water supply line (self tapping valve) is installed on this line just below the floor (makes me wonder - only black deposits downstream of this self tapping valve)??
    The one other item that might be in play is that I occasionally get a whiff of sour gas smell from my sink in the Mstr Bath. I had attributed it to rotting material in the sink drain (overflow?), but now wonder if it is related to this pipe, as we don't seem to get this odour at any other sinks (relatively good water here, just a bit of hardness).
    Any suggestions? Do I need to worry?
    Jan 2008
    I cannot see anything there that would bother me. Pure speculation, but perhaps it is caused by chemicals out-gassing from the ABS in the adjacent drain pipe.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    The cold pipe may have tarnished more because condensation forms on cold pipes. If the air in the wall is warmer than the water pipe condensation will form on the pipe. Warm pipes and or hot water pipes do not form condensate on the outside of the pipe. The pipe stays dry.
    Apr 2011
    NC
    Quote Originally Posted by KCinToonTown View Post
    I picture from under that sink of the plumbing might help us to diagnose your problem.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    The plumber may have had an old/dirty stick of copper.
    Condensation on the cold water pipe. The same thing happens in basements.
  1. purging warm water from cold line
    By bikeythekid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2012, 11:04 AM
  2. Bladder to feed a cold water line that has low flow on city water.
    By FBXFixIt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2009, 09:58 AM
  3. cold water line shaking when tub fills?
    By roadk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2009, 06:29 AM
  4. burnt odor out of cold water line
    By mroger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-30-2009, 05:20 AM
  5. Ice maker line from cold line of water heater?
    By ccash in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2004, 06:20 AM
