Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Consistent water, but low pressure
  1. #16
    DIY Junior Member JD3263's Avatar
    Apr 2013
    FL
    Just to ensure I understand, there are two tests I can do now.
    1. Cap the end of the pipe that leads to the tank and pressurize the pipes to see if it holds. If it does, then there is no leak in that entire section. How do I pressurize that section?
    2. Attach the pump to a new pipe. Cap the end of that pipe with a valve and a pressure gauge. Drop the pump down the well and start it up. With the valve closed, the pressure should build. Will it burst if I don't open the valve or shut off the pump, as in it will keep building pressure?
    I'd be performing something similar to this test, right? ... Here.
    Thank you all for your help!
  2. #17
    Feb 2011
    NW Ontario, Canada
    For test #1, use an air compressor.
    For test #2, start the pump with the valve open and slowly close it, watching the pressure. Starting on a fully closed valve might burst the pipe.
  3. #18
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    I always check the drop pipe first using the pump so I know what I have to work with, then I check the offset piping using the pump.
  4. #19
    Apr 2013
    FL
    After running through the tests we were able to narrow it down to the pump.
    Thank you for all the help! I've learned a lot!
  1. Low water pressure from water coming out of acid neutralizer. Bypass pressure is OK
    By rob742 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-28-2013, 10:35 AM
  2. ? Home water pressure and needing Pressure Regulatory valve
    By sammy617 in forum Water Heater Forum, Tanks
    Last Post: 02-06-2013, 10:10 AM
  3. Water hammer bouncing pressure gauge needle AFTER pressure tank fills
    By hawkhunter in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2012, 10:35 AM
  4. Water on and off, never consistent. Where to look?
    By guth in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-27-2010, 09:50 AM
  5. Water in well, pump working, can't build up pressure, but doesn't lose pressure????
    By bgnotaplumber in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-20-2007, 10:32 AM
