Hello Everyone,
I am new to the forum and have a question about a sink and toilet vent tie in.
I am doing all the rough work, but have a friend who is licensed, former union plumber now on his own, does great work and will be doing all the final plumbing. I have not bounced this off him yet as he has been busy, so wanted to post here to see if it can likely be done.
The bathroom I am adding is new, there is no vent stack, however close to where the drain will be going into the basement and into the sewer there is a large 4-5 inch (maybe larger diameter) vent that comes off the main sewer connection inside my basement that runs to the street and vents to another location outside the house.
Can I use this as a vent for the first floor bathroom? I would rather do this than run a new stack which would have to run up the bathroom wall, through a closet on the second floor and eventually through the roof. The vent pipe in the basement has been there for years and I never had a problem with it, so thought it would be a lot easier and better aesthetically to you this.
Here is a rough drawing of how it is set up. I appreciate the input. In the end I want it set up right, so whatever I need to do, I will do.
I am fairly handy, I build, restore race musclecars, hot rods, boats...I am not expert on home building, but remodeled my whole house on my own, with friends overseeing parts of it ie. master electrician friend helped out with electric etc.
Thanks in advance, Tim
