Results 1 to 12 of 12
Thread: Pegasus Shower Cartridge Removal
    DIY Junior Member rev12's Avatar
    Jan 2014
    new jersey
    Default Pegasus Shower Cartridge Removal
    Hi,
    My shower has had a slow week for a number of days and i am having pegasus send me a new cartridge which i believe is the problem. The problem i am having is that i have removed all the parts i think that need to be removed but cannot get the cartridge out. I have included a picture of the cartridge. Any help would be very appreciated.
    It looks like it should just pull out, but we do not know what you have removed so far, so we do not know if something you removed held it in, or if the retainer is still there "somewhere".
    Jan 2014
    new jersey
    I removed the sleeve surrounding the cartridge as well as a red cap piece that was fitted around the white piece of the cartridge. I don't see any retainer pin to pull out. so i'm kind of stumped.
    Jan 2014
    new jersey
    here is another picture if it helps at all
    That "multisided" brass piece is the retainer. Unscrew it, then grab the white stem and pull HARD to remove the cartridge.
    Jan 2014
    new jersey
    ahhh ok. thanks. will try and report back. i had unscrewed only the top piece of the retainer then i guess. would make sense the rest of it would unscrew out of there.
    Jan 2014
    new jersey
    i did get some more info with updated pictures as to what i have already taken off. The shower unit is a Glacier Bay Lyndhurst 1-Handle Tub and Shower Faucet in Brushed Nickel
Size:  24.0 KBName:  Shower 1.jpg
Size:  36.1 KBName:  Shower 4.jpg
Size:  28.7 KBName:  Shower 5.jpg
Size:  33.3 KBso i was not able as of yet to remove the cartridge.
    Jan 2014
    new jersey
    I guess my question would be. Does the piece that has threads screw out of there? or does the whole assembly screw out from all the back where it meets the pipes?
    DIY Senior Member Vegas_sparky's Avatar
    Dec 2013
    LV,NV/ Nowhere,UT
    I would try a strap wrench on the nickel sleeve surrounding the cartridge. They're two different materials(sleeve and brass rough in) and have to separate somehow.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Here is a diagram of your valve, I think Vegas_Sparky is correct .
    You have to remove the bonnet.
    http://www.homedepot.com/catalog/pdf...e5448b0920.pdf
    That "threaded thing" has "flats" on the sides so you can use a wrench to unscrew it. Just unscrew it and pull the cartridge out, as you were told previously.
    Jan 2014
    new jersey
    i got the threaded piece off last night. was just on their tightly and i was afraid of doing something wrong. i used a wrench on the flat side of the threaded piece and it came right off. thanks for the help
  1. Moen Shower Cartridge Removal Tool
    By HawkeyeSean in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-10-2013, 06:23 AM
  2. Replacing cartridge for Pegasus Shower
    By pstevnesontx in forum Shower & bathtub Forum & Blog
    Last Post: 09-24-2013, 05:50 PM
  3. Need Urgent Help for Tem Cartridge Removal
    By starchoice in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-04-2010, 08:21 PM
  4. Moen T4570 cartridge nut removal
    By cpeters in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-31-2009, 04:23 PM
  5. Pegasus series 7000 cold water faucet cartridge removal
    By shawv in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-11-2007, 06:44 AM
