Thread: New Furnace
    Default New Furnace
    Good Morning, Thinking of replacing a Luxaire Furnace within the next few months in our home, what brand would all of the HVAC pros on here encourage their customers to buy? Thanks
    Gas, oil, propane?
    Sometimes, it's a tossup, based on what the guy you have install it prefers and knows how to setup properly.
    First thing, though, is to probably figure out the size of the unit you really need...older ones are almost always oversized, often by a lot. Max comfort calls for the thing to run a lot when it is really cold out. Lots of on/off cycles is not very efficient, nor does it help with the longevity of the thing.
    One option that I really appreciate is a variable speed fan. It starts out slow until the heat exchanger gets warm, then speeds up as required. WHen done, it also slows down gradually to extract all of the heat in the heat exchanger. I do not normally ever hear mine running. This is available on many brands (mine happens to be Trane), and, at least to me, is a very worthwhile upgrade from a standard system's single speed fan. There are also two stage output furnaces that help match the load, and improve both comfort and economy. Whether the economy would ever pay for the comfort improvements, I've not worked out, but the unit is more efficient than my old one.
    DIY Member rosem637's Avatar
    Jan 2013
    Michigan
    Quote Originally Posted by Fudog View Post
    Whichever one they can get at least cost to them and sell to you at top dollar.
    Nov 2010
    Maine
    Really? I don't sell bottom of the line anything.
  1. Just i want a new furnace
    By jbill303 in forum HVAC Heating & Cooling
    Last Post: 10-23-2013, 07:53 PM
  2. What is this and what does it do for my NG furnace?
    By greaper in forum HVAC Heating & Cooling
    Last Post: 04-28-2013, 06:22 PM
  3. 60,000 vs 80,000 BTU furnace
    By CurbYourEnthusiasm in forum HVAC Heating & Cooling
    Last Post: 02-18-2013, 05:11 AM
  4. Conversion from gas furnace to electric furnace
    By debka in forum HVAC Heating & Cooling
    Last Post: 01-19-2013, 06:39 AM
  5. What furnace should we get?
    By Sincraft in forum HVAC Heating & Cooling
    Last Post: 09-02-2007, 01:13 PM
