Results 1 to 3 of 3
Thread: How to connect new tub drain to old 1&1/2 brass drain
    DIY Junior Member Willhelm's Avatar
    Jan 2014
    Pittsburgh
    Default How to connect new tub drain to old 1&1/2 brass drain
    Name:  tub drain.jpg
    I am replacing a tub and will be adding a new drain. I will have to remove the old brass trap as well as brass drain. I don't know what type of drain assembly to use (PVC,ABS,copper) or how i can connect it to the 1&1/2 brass drain pipe exiting to the left of the picture. Basically, I'll be removing everything in the picture and will be left with the brass drain pipe on the left. So, I have to replace the drain & overflow on the tub and tie into the brass 1&1/2 pipe exiting picture on left (after trap). What's the best way to go about this?? Thanks Bill
    They make a shield coupling that goes between copper sizings and plastic.
    The type of plastic will be determined by the waste and overflow you buy.
    Like this but for 1-1/2"
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Go with PVC or ABS drain set and trap. Use the coupling mentioned above to connect to the waste line on the left (must be PVC or ABS to copper).
  1. How to connect PVC tub drain to ABS waste
    By CheetahGeek in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-20-2013, 02:22 PM
  2. How to connect ABS Drain to Brass P-Trap
    By GoruckDIYer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2012, 07:53 AM
  3. Connect toilet directly over main drain. 3" clearance under subfloor to top of drain.
    By zx6e in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-06-2012, 09:05 AM
  4. Connect second floor shower drain into first floor kitchen drain
    By lanthoma in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2008, 07:02 AM
  5. how to connect plastic shower drain to 2" copper drain line?
    By showerpain in forum Shower & bathtub Forum & Blog
    Last Post: 01-31-2007, 08:36 AM
