Results 1 to 6 of 6
Thread: Rust in water tank
    DIY Junior Member jack z's Avatar
    Nov 2013
    Ft Myers
    Default Rust in water tank
    I have city water the house is 12 yreas old with pvc pipe. I just replaced my 3rd elect. water tank. The tank gets rusty and has to be replaced, I do have a water softner unit also and wonder if the water softner is creating the rust problem. No info from my local plumber or the water softner company. Thank you jz.
    Sep 2013
    Do others in your neighborhood have short lives on water heater tanks? I am guessing that your city water is particularly corrosive.
    When you say rusty, I am guessing you mean the tank leaks.
    I would consider using a powered anode to prevent internal rust. While it costs more, you don't have to change out the anode, and can, in fact, move the anode to the next tank.
    Nov 2013
    Ft Myers
    Quote Originally Posted by Reach4 View Post
    No the others have no problem tanks are over 14 yrs. old they are on city water but no softner units.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Depending on several factors of your drinking water, reducing the hardness may result in corrosive water. Waters softer than 50 mg/l CaCo3 is considered to be corrosive. You would need to do a chemical water sample to be sure.
    http://www.cleanwaterstore.com/techn...s/langlier.php
    Water is sometimes called the universal solvent...yes, it can take millennia, but most things can be dissolved by it. The purer it is, the more aggressive it is. That being said, most of the time, it's luck of the draw.
    DIY Member dw85745's Avatar
    Oct 2004
    Arizona
    As I recall, when we started using Colorado River Water ( in Tucson, AZ) there were a lot of pipe problems because of the "Ph" of the water.
    I know pinhole leaks in copper (especially horizontal lines) is of a particular problem because of "Ph".
    1) I would have your "Ph" tested (your water company should provide a list of chemicals in the H20 as well as "Ph" on a periodic basis.)
    2) You MAY be getting H20 from a different well than your neighbors.
    3) If the same well, I'd look to see what your H2O lines are made of.
    If black or galvantic pipe they may rusted (on the inside) and dumping rust into your tank.
    4) Maybe getting a dialetic reaction. Are you using dialetic nipples (plastic coated) -- or -- copper fittings (not brass or stainless steel) to galvanized fittings or to the tank?
    Some research seems to indicate improper electrical grounding of the house contributes to tanks rusting faster (causes these dialetic problems)
    5) That said, all H20 Tanks rust inside, and maybe your neighbors have bought a 12 to 15 year tank, where yours is just a 6 year tank.
  1. Rust in my Water!!!!
    By Tully23 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-23-2011, 06:05 PM
  2. Tank Bults Either Rusting or Causing Rust
    By teqnic in forum Toilet Forum discussions
    Last Post: 04-23-2009, 03:31 PM
  3. WH Expansion tank rust-through?
    By scargoz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-16-2008, 12:43 PM
  4. Rust in my well water
    By dongreen in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-02-2008, 06:32 AM
  5. tank tablet for rust/hard water
    By ddmoit in forum Toilet Forum discussions
    Last Post: 01-28-2007, 12:52 PM
