nltaylor32
I bought a cabin this year. It has 2 bedrooms and 1 bath. The original owner was a Hungarian immigrant and built the place himself, and also drove a sand point well by hand. The well is located inside in the basement. The pressure tank and the pump all seem to be near brand new, I’m guessing installed by the previous owner (not the original owner).
The water from the well is full of iron bacteria, and all of the water fixtures, bathtub, sinks, toilets were stained from the rust. So, I had a Lindyspring system installed. The Lindyspring system consists of a berm filter/softener unit and then a sanitizer unit. Both units require “regeneration†after 900 and 600 gallons, respectively, of water use. When the regeneration cycle runs it draws the pressure tank all the way down to 0 psi and the pump runs continuously for up to 15-20 min after which it feels warm to the touch. Fortunately 600 gallons lasts usually about 4-6 weeks, so I am not regenerating very often, but I am worried I may be putting a lot of stress on the pump.
I feel that a big part of the problem is that the suction side of the pump has been reduced to 3/4†(from 1-1/4â€) but has 1†on the discharge side. The well has a 2†steel pipe casing. At the top of the casing is a cap that has been modified to take a 3/4†fitting and then a 3/4" hose runs from the well to the pump. I was going to attempt to change the cap on the well casing so I could run a 1-1/4†connection from the well to the pump, but when I removed the cap I found that a 3/4" hose was connected directly to it and was being used for a drop pipe. I was expecting to find a check valve inside of there??
Does anyone have any suggestions for making improvements to this system that wouldn’t be a significant expense?
Here are the details that I know:
Jet Pump
One pipe down the well
Size of Pump?
Motor Horsepower? 3/4
Pump Model # Red Lion
Date Pump Installed ??? less than 24 mos.
Pumping from?
Water Well / Hand driven sand point
Depth of well - ?? less than 25 ft.
Depth to water- ??
Pump Setting - ?
Pipe Size 1 1/4" reduced to 3/4" on suction side and 1" on discharge
Drop Pipe Material - Plastic rigid hose
Well Recovery Rate_______gpm
Well Casing Diameter 2"
Rock Well__________ Sand Well__________ Other______________
Date Well Drilled - ??
Well Casing Material
PVC________ Steel_____x____ Other_________
Pressure Tank?
Bladder or diaphragm tank (one pipe to tank) - Bladder
Size or model of tank____flotec 42 gal________
Air charge in top of tank, with pump off and water drained_____38_______PSI
(check with car tire gauge)
Pressure Switch Setting?
On 30, off 50 ___x_____
Pump Control Method?
Cycle Stop Valve model #_________
Variable speed control #__________
Pump Start Relay (sprinkler timer, no tank)__________
Manually turned on and off____________
Pump Protection
Cycle Sensor_________
Pumptec_____________
Low pressure cutoff switch (lever on side)__________
Other_______________
Filters or Softeners - Sediment Filter, followed by a Lindyspring system, softner/sanitizer
Before or after pressure tank - After
Type of filter_____sediment filter is paper cartridge_____________
Bypass available_____no on the sediment filter, yes on the Lindyspring System_________
Water Used For?
House Use___X____ Number of baths____1___ Number of People____2____
High Flow Showers_______gpm?
Plus/Or
Irrigation with timers________
Irrigation with hoses________
Heat Pump______gpm?
Problems Experienced
No Water_________________
Water only part time________
Water at all times but weak_____
Air in water_______________
Pressure surging___________
Water Hammer (noise)______
Too Much pressure_________
Other______Drawdown during Lindyspring regeneration cycle______________
Pump makes clicking or buzzing sounds________
No Sounds______________
Pressure gauge reading________psi
Other____________________________________
Do you have, and know how to use
an Ampmeter and Voltmeter__________________
