Results 1 to 9 of 9
Thread: Well issues after cold NC night
    DIY Junior Member Shakes's Avatar
    Jan 2014
    North Carolina
    Default Well issues after cold NC night
    I am a new home owner with very little knowledge of wells and pumps. I have a submersable pump with an insualated pump house but I neglected to turn on the pipe heater wires (Extension cord trype things wrapped around the pipes, they are now on). Woke up this morning to no water after leaving the faucets dripping overnight. After using a hairdryer on thin pipe below the pressure switch i heard a click and the water began to flow inside. The water was not flowing evenly and was pulsating a bit but the pressure was good. I went out to the pump and the pressure switch was short cycling constantly. it was also leaking out of the pressure vavle when it was cycled on. About a few tablespoons per cycle would weep out. It cycles twice about every minute with the water in the house off. If anything is on in the house the switch continuously cycles on and off but water flows somewhat normally inside. The pressure valve leaks while it is short cycling. I repaced the pressure switch and the pressure valve but the issue is still there. I noticed the large blue pressure tank meter shows zero pressure. I also tested the fitting at the top of the tank and the pressure was neglidgable at best. It did hiss slightly. I am waiting on a plumber but they can not say when in the next two days they will be able to get here. I have a friend coming by leter to see if he can figure it out. Any ideas?
    Should I keep the pump on or off? Name:  DSCN9953.jpg
Size:  86.1 KBName:  DSCN9954.jpg
Size:  61.0 KBName:  DSCN9956.jpg
Size:  71.0 KBName:  DSCN9957.jpg
Size:  56.6 KBName:  DSCN9958.jpg
    Jan 2014
    North Carolina
    Well it seems to have stopped short cycling. The water in the home is no longer pulsing and the pressure switch does not cycle even with the water running. I have no been able to get it to cycle at all but im not sure if it should. Plus I have to keep running in and out of the house to turn on/off the water so I could be missing it. Pressure inside is normal. Pressure still reads 0 on the tank. Perhaps something thawed? Im thinking I am going to still have the plumber come by to inspect my work and make sure everything is working normally. If I threw awat $40 on a pressure switch and valve that were not needed im not upset. Now I know how to do that
    Do you think I am out of the woods?
    Jan 2014
    North Carolina
    It has warmed up to 28. Its going to drop down to 12 tonight and tomorrow we should be back to normal NC weather.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Keep it warm and put a Romex connector on the wires going into the pressure switch
    Jan 2014
    North Carolina
    Will do. Thank you sir!
    Moderator valveman's Avatar
    Mar 2006
    Your gauge doesn't read 0, it reads about 140. They wrap all the way around like that when they freeze. Get another gauge so you can see what is really going on.
    Jan 2014
    North Carolina
    I will do that thank you sir. When I tried to take a reading from the top with my bicycle gauge its so low it barely moves the stick. There was a slight hiss of air though so its not dead but its very low. I just took another reading from the top valve and its at 45 Psi.
    Mar 2006
    Quote Originally Posted by Shakes View Post
    Make sure the pump shuts off. You need to add air to the tank first chance you get.
    Jan 2014
    North Carolina
    Yes sir it does. I wasn't able to see it happen so I manually moved the pressure switch. It engaged for about five seconds and shut off. I don't have a compressor but I have a plumber coming by tomorrow afternoon check everything out.
  1. A night out at the VFW
    By Cookie in forum Terry's Corner
    Last Post: 08-07-2012, 08:32 PM
  2. Forum down last night?
    By jimbo in forum Computers and Stuff
    Last Post: 05-27-2009, 10:18 AM
  3. T&P discharged last night
    By firefly in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-15-2008, 01:09 PM
  4. Bad night at work
    By got_nailed in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-01-2007, 05:01 PM
  5. Day & Night (BDP) BTU level
    By dutch in forum HVAC Heating & Cooling
    Last Post: 05-16-2007, 11:53 AM
