Results 1 to 2 of 2
Thread: Help with tub to shower conversion, water line reroute
    DIY Junior Member loudgonzo's Avatar
    Jan 2014
    Wylie, Tx
    Default Help with tub to shower conversion, water line reroute
    Hi guys,
    I was suggest by a member on another forum to ask about a tub to shower conversion I am doing here. I removed the old "original" tub and found the builder routed the water supply line outside the studs, and now it does not allow us to put the wall up because the tubing is in the way.
    A couple options are to build the wall out to make room for the water lines, or cut notches into the existing studs and use rigid pipe to route the lines flush with the studs.
    Is there another option we can do, or a is any one of the above better than the other?
    Thanks in advance,
    leoName:  photo (29).jpg
Size:  48.5 KBName:  tearout 2.jpg
    Pick up a 1-3/8" drill bit and put the pipes in the wall. You may need to rent a angle drill for that.
    Or.........you can notch the wall studs.
    With the old fiberglass enclosures, you can get away with a bit more as far as location of the piping.
  1. Best method to reroute 1/2" copper supply line to allow Vent duct through wall?
    By DIY007 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-19-2012, 05:58 PM
  2. Tub to Shower Conversion
    By Ricleb in forum Shower & bathtub Forum & Blog
    Last Post: 05-03-2011, 07:10 AM
  3. Tub to Shower Conversion
    By shamrock_94 in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2006, 04:34 PM
  4. Tub shower conversion help
    By kpaisley1 in forum Shower & bathtub Forum & Blog
    Last Post: 07-30-2005, 02:33 PM
  5. Reroute Soil & Waste line?
    By yarrumretep in forum Remodel Forum & Blog
    Last Post: 01-30-2005, 04:45 PM
