Shawn Clabough
I have a 5600SXT unit with an 18x33 round brine tank. Approximately how high should the water be in the tank during and after a cycle?
View attachment 22481 With BF 10, if you have a .5 GPM BLFC (Brine Line Flow Control ) , you would be using 15 pounds of salt per regeneration. If your BLFC is 0.25, BF 10 sounds good..50 GPM
1.5 LB
SALT/MIN
I had made a mistake in labeling the capacity as H instead of C. I have edited. I don't have a particular thought on the others, but I don't see why they would change.So what should BF and C be for my unit? I assume BW, BD, and RR should stay the same.
