Thread: Protecting water softener
    DIY Junior Member opto_isolator's Avatar
    Dec 2013
    Florida
    Default Protecting water softener
    I just finished installing the water softener tonight, hooked up CPVC lines. Is there anything that anyone has done to prevent the resin tank from moving? I can see that if someone or something moves the tank, it may crack the lines.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    I bury the tanks into the ground about 1' if installed outisde. If the unit is sitting on concrete, it will take a very hard hit to break the pipes. You can strap the pipes to a wall if they are close enough.
    Dec 2013
    Florida
    Quote Originally Posted by mialynette2003 View Post
    Thanks for the feedback - it's in the garage in the corner.
    Jan 2012
    California
    You can secure the tank to the wall if you like. This is not usually necessary. You can secure it in a similar way that water heater tanks get secured. I use large unistrut clamps http://www.mcmaster.com/#strut-channel-clamps/=q50xmb They look professional and work great. they are also fairly inexpensive. I use the 304 stainless, less than $20 for the clamp, the strut varies greatly in price depending on material, size, etc.
  1. Best way of protecting banisters from harm during demolition
    By johnfrwhipple in forum Remodel Forum & Blog
    Last Post: 05-20-2013, 02:41 PM
  2. Protecting copper from cast iron
    By sethamin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2013, 02:15 PM
  3. Protecting new tile floor?
    By ingeborgdot in forum Remodel Forum & Blog
    Last Post: 12-02-2010, 09:42 AM
  4. Protecting PEX from UV
    By HDClown in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2010, 10:32 AM
  5. Protecting MC wires in PT framing
    By Taylor in forum Electrical Forum discussion & Blog
    Last Post: 04-17-2008, 08:01 AM
