run natural gas line for fire pit from house
floyd6977
sann diego
Am i within code(or close enough) if i dig a 6" trench around my patio with PVC and run the gas line through that into fire pit connection?
It should be at least 12", and maybe deeper, depending on the type of pipe you use. Even in a PVC sleeve, if could get the pipe through it, the material you use is critical.
Dj2
California
Contact your local gas supplier for exact requirements in your area. 6" is definitely too shallow for any pipe.
DonL
Houston, TX
I would hope that was width.
Some people should not be playing with gas.
Dj2
California
One more thing: you will probably need a permit for what you want to do.
Doing gas line work is not a job for homeowners or DIYers, even though digging a trench is. Call a lic plumber.
