Thread: Working sink for show display
    In the Trades rob herman's Avatar
    Jan 2014
    Toledo, Ohio
    Default Working sink for show display
    I work for a remodeling firm in Toledo, Ohio and we are looking to have a portable functioning sink for a show display. We would like to have a Touch2O faucet that would function normaly in our kitchen display. Does anyone know the steps it would take to make this happen? Any information or guidance toward more articles would help immensely. Thank You in advance
    Sep 2013
    I think you are implying that for show you are probably going to want recycle the drain water to be fed back out of the faucet under pressure.
    Nov 2010
    Maine
    Yep, get one on the small under sink pump/tank sets and pipe the drain back to the faucet.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    I would set it up with a something like a Shurflo pump. I would use an electric pump if electricity is available if not you could use a 12 volt pump. You will need a tank to pump out of and for the water to drain back into. You may be able to recirculate the water or set it up like an RV with a fresh water tank and a waste tank.
    http://www.shurflo.com/rv-products/r...l/default.html
  1. Burnham Alpine 80 Display
    By cad53 in forum Boiler Forum
    Last Post: 11-01-2011, 01:04 PM
  2. Installing indicator light to show pump working
    By blued in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-28-2011, 03:47 PM
  3. Using Faucet Display Model
    By Big Al in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-03-2007, 10:03 AM
  4. Blank display on irrigation controller
    By La Duena in forum Irrigation / Sprinkler Forum
    Last Post: 08-22-2007, 01:02 PM
  5. sink not working
    By para1911 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-09-2006, 10:51 AM
