Results 1 to 5 of 5
Thread: burnham alpine 105 boiler ignition issues
    DIY Junior Member jdog_kustoms's Avatar
    Jan 2014
    Biglerville pa
    Default burnham alpine 105 boiler ignition issues
    i have had trouble with this boiler since new big regret getting it but anyways the latest issue has me lost and i am a certified hvac tech not a home owner my boiler wont light off all the time and locks out on ignition falure code #11
    i have 14 inches of gas pressure when gas valve is closed and 11 when i do get it to run and burn
    have new ignitor and good spark
    cleaned the flame rod
    i have been having issues since new had to replace the ignitor boot under a recall then replace the hole saga board and ignitor boot again also under recall but i can never get the boiler to work all heating season with out having to keep reseting it but now it needs reset all the time
    any suggestions would be greatly appriciated
    DIY Junior Member jac04's Avatar
    Dec 2013
    I would suggest looking at the gas piping system. It may be undersized resulting in gas supply issues.
    I too currently have ignition issues with a propane boiler. First, the piping was way undersized and the regulator couldn't keep up. Ignition was always a big problem, and it would sometimes lock out on ignition failure. Then, the supply piping was upsized (by the plumber) and a hi/low regulator system was installed (by the propane company). This helped a lot, but I still have intermittent ignition problems, and if any other propane appliance is running, I have bigtime ignition issues. I'm trying to get this fixed now, as the propane supplier says the supply piping is still too small.
    My static and running gas pressures look good as well, but I definitely have gas supply issues, and I think you do too.
    Mar 2011
    Houston, TX
    If Gas pressure is good at the unit, Then you may want to look at the spark gap and positioning.
    Good Luck.
    Jan 2014
    Biglerville pa
    i have 3/4 inch black iron from tanks to the boiler reduced to 1/2 about 4 foot from the boiler and only have the boiler running off of the line and i have replaced the ignitor and still have the same issue and checked the gap it is to factory specs
    Mar 2011
    Houston, TX
    Quote Originally Posted by jdog_kustoms View Post
    That still don't tell you that the unit is getting the proper amount of gas.
    I hope you are adding a little air too. Maybe a safety has you hosed, well it is just working.
    Good Luck.
  1. Burnham Alpine 105
    By Capindres in forum Boiler Forum
    Last Post: 01-22-2014, 12:37 PM
  2. Question about Burnham Alpine 150 BTU Boiler question
    By JDL in forum HVAC Heating & Cooling
    Last Post: 01-12-2014, 10:07 AM
  3. Wiring Burnham Alliance Indirect to Burnham Alpine
    By cyruspinkney in forum Boiler Forum
    Last Post: 10-25-2013, 01:28 PM
  4. Thermostat to control new Burnham Alpine 105 boiler
    By 2Bgreen in forum HVAC Heating & Cooling
    Last Post: 09-18-2012, 08:36 AM
  5. Burnham Alpine 105 boiler
    By adepina in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-04-2012, 03:10 PM
