Thread: Delta Crystal Knob Questions
    DIY Junior Member ClassicTVMan1981's Avatar
    Mar 2013
    Milwaukie, OR, US
    Default Delta Crystal Knob Questions
    Happy New Year's Day everybody!
    My question to kick off 2014 is this: would any of you know what to do to maintain the clearness of any Delta clear knob handle, like the one on my 642 tub/shower faucet?
    The suggestion that is floating in my head is to use Vaseline around the entire Duralac knob. Repeated baths and showers will, without maintenance, destroy the clearness of the knob, making it cloudy.
    Thank you,
    Ben Edge (ClassicTVMan1981)
    Jul 2009
    North Vancouver, BC
    Vaseline? Really?
    What is your mind set here?
    These knobs will fade with hard cleaning agents.
    Fade with hard scrub brushes.
    But can come back to looking quite good with a good soak and wipe down. I find cleaning them inside and out best if the fixture is old. I think we bleached one once and it heaped a lot.
    Does the shower fixtures see any sun rays? Maybe a better shade will help you out long term.
    Mar 2013
    Milwaukie, OR, US
    Quote Originally Posted by johnfrwhipple View Post
    Vaseline? Really?
    Delta recommends using these procedures to maintain the clearness of these knobs:
    Always blot dry any water from the faucet surface. Allowing water to evaporate on the surface can lead to build up of mineral deposits. Cleaning with a damp, non-abrasive sponge and letting it dry with a clean soft cloth should help keep your product looking beautiful. To remove water spots, use warm water and a soft, damp cloth. Hard water stains may be removed with a 50/50 mixture of white vinegar and water. Make certain to completely rinse with water afterward.
    WHAT TO USE IF ADDITIONAL CLEANING IS REQUIRED (follow manufacturers' directions)
    Formula 409 Antibacterial All Purpose Cleaner
    Fantastik All Purpose Cleaner
    Windex Original Glass Cleaner
    WHAT NOT TO USE
    Any industrial or abrasive cleaners designed for use on toilet bowls
    Green Scotch-Brite scrub sponges
    Scrubbing Bubbles Bathroom Cleaner
    Lysol Basin Tub Cleaner
    Soft Scrub
    Tile Cleaner
    Harsh abrasives/polishes
    Bleach-based cleaners
    ~Ben
    Jul 2009
    North Vancouver, BC
    I can see fantastic and windex working - just not sure what Vasiline will do.
  1. Delta Shower Valve with Temperature Knob
    By themp in forum Shower & bathtub Forum & Blog
    Last Post: 01-20-2013, 05:13 PM
  2. Delta R10000 rough in valve questions and more
    By Finch85 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-10-2012, 09:56 AM
  3. any ideas??? DELTA SINGLE KNOB SHOWER-REPLACED WITH PP SINGLE LEVER
    By randy m in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2007, 06:44 AM
  4. Two knob to three knob shower?
    By enviroko in forum Shower & bathtub Forum & Blog
    Last Post: 05-04-2007, 06:32 AM
  5. Shower leak and knob questions
    By jwr in forum Shower & bathtub Forum & Blog
    Last Post: 11-12-2006, 11:09 PM
